Which octane do you use?
Old Aug 14, 2011 | 12:47 AM
  #61
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
Originally Posted by QUAKEJAKE
You won't get detonation because the computor pulls timing to save the motor which in turn will lower performance. That's a given. If you can't notice the difference you need to find the go pedal
Actually, the predetonation is what trips the knock sensors which tells the PCM to pull timing.
Old Aug 14, 2011 | 08:12 AM
  #62
Readygo's Avatar
Readygo
Only use 91 octane thats what it calls for
Old Aug 14, 2011 | 08:51 AM
  #63
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Originally Posted by cobraduke
Sorry I'm so dumb.
I didn't read all the answers so if someone else said this, I'm sorry. The only dumb question is the question you don't ask. I believe the answer is premium. (It gives me piece of mind if not anything else).
Old Aug 14, 2011 | 10:04 AM
  #64
QUAKEJAKE's Avatar
QUAKEJAKE
Originally Posted by j_digi454
Actually it is saying a lot. That is over a 15% increase in gas mileage which translates to the equivalent of paying $.60 less per gallon (assuming $4.00 per gallon) for a premium fuel which should make your cost lower than the cheaper stuff and you get the benefit of the additional additives of a Top Tier fuel.
If everyone reads only one post in this thread this is the one.
Old Aug 14, 2011 | 10:13 AM
  #65
wkidvette's Avatar
wkidvette
91 octane
Old Aug 14, 2011 | 10:32 AM
  #66
surburban99's Avatar
surburban99
I have always used 93 octane fuel, why would you use anything less?
Old Aug 14, 2011 | 09:44 PM
  #67
Jimsan's Avatar
Jimsan
Default Octane
Up here (mile high) 87 works fine. Plus the cost savings help me pay for my Obamacare supplemental insurance
Old Aug 14, 2011 | 10:16 PM
  #68
Gary '09 C6's Avatar
Gary '09 C6
93 octane, as the OM recommends..
Old Aug 14, 2011 | 10:20 PM
  #69
rayk's Avatar
rayk
92-93 octane at BP stations. Extra 2-3 bucks over regular for the fillup.
Old Aug 14, 2011 | 10:28 PM
  #70
EDinPA's Avatar
EDinPA
Originally Posted by La Orange
Hi All
Last month I was on a trip following a friend. He was driving his 2006 C6 auto coupe I was in my 2005 C6 6manuel convertible.
At a gas stop he filled up with regular I thought he made a mistake.
He said he has run the car on regular almost always since first got it " 130K miles "
He said it has a slight bet more power on 91 or 93 but very slight
The next fill up I tries 91-E10 and the car ran the same Except I drooped
a little less then 1 MPG on the highway.
One other thing i have found is if i can find and run Pure Gas
" No ethanol " I pick up 1 plus MPG on the highway
Not taking sides just passing on my experance
Michael
Ethanol will always get lower MPG then real gas. Less energy per gallon.
But this is a separate issue from octane rating.
93 for me.
Old Aug 15, 2011 | 06:18 PM
  #71
QUAKEJAKE's Avatar
QUAKEJAKE
British Petrolium,They're still around? Got so bad for them around here that within 6 months after that God awful catastrophy all the area stations closed down due to well informed Americans deciding to get their fuel elsewhere.What goes around comes around.
