Which octane do you use?
Old Aug 12, 2011 | 12:25 PM
cobraduke's Avatar
cobraduke
Default Which octane do you use?
I've had several C6 Corvettes and have used premium fuel in all of them. Today a dealer told me that I should be using regular fuel, and will not notice any difference in performance. What do you think?
Old Aug 12, 2011 | 12:31 PM
aw88071's Avatar
aw88071
Base C6 was tuned to run 91. You can run 87 without problems, but you may notice a small performace decrease (Due to timing changes to prevent knock). Running anything higher is a waste of money unless you have power adders or are going to tune it.
Captain Richard's Avatar
Captain Richard
I think your dealer should seek alternative employment.
Old Aug 12, 2011 | 12:32 PM
topper7788's Avatar
topper7788
Here we go......
By the way I'm an ex dealer and run regular...have for years... No issues...i know im in the minority on this one, but over the years i have been told by several factory engineers its basically a non issue for the car... And of course 98% of my driving nowadays is cruising. If I expect I will be pushing the car I'll top off with Premium.... I'm talking LS2 and 3... on LS7 premium is needed....
C7Joy's Avatar
C7Joy
I use 93 because it happens to be the premium grade where I usually gas up. I would be comfortable using 91 or whatever the manual specifies. Why do any less for a $50,000+ car?
Old Aug 12, 2011 | 12:33 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Sure you can use regular gas, but when the engine knock sensors sense even the slightest amount of detonation (from the low octane gas), the PCM will pull timing out of it and you will lose HP.
The problem will worsen in the hot sumertime when engine cylinder head temps go way up.
Not a great idea ... stick to what the owner's manual tells you. GM knows a little more about these engines than some guy at a Chevy dealership.
Old Aug 12, 2011 | 12:38 PM
johan gouws's Avatar
johan gouws
Old Aug 12, 2011 | 12:43 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Typical difference between filling up with regular versus "supreme" is something like $1.60 to $2.20
Stupid reason to use regular....
Old Aug 12, 2011 | 12:51 PM
jackhall99's Avatar
jackhall99
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Originally Posted by johan gouws
Old Aug 12, 2011 | 12:53 PM
dvilin's Avatar
dvilin
dvilin's Avatar
dvilin
Old Aug 12, 2011 | 01:10 PM
Thrash's Avatar
Thrash
I use 93, but one time I filled with 87, to see ... and I saw
A serious difference in power and response. Sure it ran okay, but I couldn't wait to empty the tank.
I hope one day to use propane or natural gas!
Old Aug 12, 2011 | 01:12 PM
KenHorse's Avatar
KenHorse
I'm waiting for ground up unicorns....
Old Aug 12, 2011 | 01:29 PM
JoesC5's Avatar
JoesC5
My Z06 REQUIRES a minimum of 91 octane but GM engineers recommend that I use 93. I only run 94 octane without any ethanol crap added. All 87 and 89 octane around here is E10 and I won't put it in my car.
Even if I could run 87 octane, the $150-$200 a year savings isn't worth it. I purchased a $80,015 high performance car and trying to save $150/$200 a year on gas is stupid.
Old Aug 12, 2011 | 01:34 PM
Kwagnerhvac's Avatar
Kwagnerhvac
I have a 2010 Grand sport now and had a 05 and have always used medium grade (89 octane). Never an ounce of knocking. I tried 93 octane and did not notice any performance or gas mileage improvement. I will continue to use 89 octane from here on out.
Old Aug 12, 2011 | 01:45 PM
bbudman's Avatar
bbudman
Stations where I live offers 87, 89, and 93 octane. I use the 93 because the manual recommend 91 octane. For no more than it cost I figure a $50k plus vehicle is worth it. It is kind of like changing the oil, go through a quick change location and let them put cheap oil and filter or follow the manual and spend a few bucks. Our cars only deserve only the best!!
QUAKEJAKE's Avatar
QUAKEJAKE
You won't get detonation because the computor pulls timing to save the motor which in turn will lower performance. That's a given. If you can't notice the difference you need to find the go pedal
To Which octane do you use?
Old Aug 12, 2011 | 01:48 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Only 93 has been put in ours and that is the way it will continue
Old Aug 12, 2011 | 02:01 PM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
93 only. Mobil, Sunoco, Shell etc. Top tier Just like the manual states. I did have a station accidently put regular(I guess force of habit). Car still ran fine. When I got to a half a tank I refilled with premium. No harm done.
I just wanted to add I got a 2011 Ford Taurus SHO. That manual reads just like the vette. Will run on regular, recommend premium. That car gets the plus, 89-91 depending on which station. That car also runs just fine.
Old Aug 12, 2011 | 02:15 PM
cobraduke's Avatar
cobraduke
Sorry I'm so dumb.
