Cold Air Intakes
Old Aug 19, 2011 | 10:03 PM
boterre2471's Avatar
boterre2471
Default Cold Air Intakes
Can someone tell me the best cold air intake to purchase. Thanks in advance.
Old Aug 19, 2011 | 10:11 PM
Luster's Avatar
Luster
You're going to get a LOT of debate on this topic.
I bought the K&N and I'm very happy with it, but some will even tell you that stock is better than any aftermarket system, at that all CAI's are a waste of money.
I think my throttle response is a little quicker, but again, that will be refuted by many, and then again, maybe it's just psychological since I spent 400 bucks and I want it to be quicker.
Old Aug 19, 2011 | 10:14 PM
CheckeredFlag's Avatar
CheckeredFlag
are you also getting a different throttle body ? I would think that would be a good item to pair up your cold air intake with
Old Aug 19, 2011 | 10:17 PM
1320fan's Avatar
1320fan
I just bought a SLP Blackwing that I'm going to go install right now. I'll have to report back with my scientific findings!
Old Aug 19, 2011 | 10:42 PM
Mike V.'s Avatar
Mike V.
Default Vararam
Absolute proven performer, people complain about probs & whine about install, but simply best performer head to head. I have on my mild cammed (228/232), & the basic bolt-ons breathing for a lil 'ol LS2 makin' 452rwhp/418rwtq. You can hear hear it, you can feel it, & at the track you can prove it! Self installed ZERO problems in 5 years.
Old Aug 19, 2011 | 10:49 PM
Luster's Avatar
Luster
Originally Posted by Mike V.
VARARAM...
I've heard nothing but good about Vararam.
Old Aug 19, 2011 | 11:11 PM
Wayne O's Avatar
Wayne O
CF Senior Member
IMO the Lingenfelter high-flow intake is one of the best true, cold air intakes. The Callaway Honker is also good. I feel a CAI is an essential component of one's overall modification plans but as a stand-alone mod its benefits are minimal. Make sure you're aware of all the pros and cons before you buy.
Old Aug 20, 2011 | 12:27 AM
C2C6Z06's Avatar
C2C6Z06
St. Jude Donor '08-'09-'11-'12
I have a Vararam on the wife's 05 LS2 - the old style that doesn't fit real well. AND I have a newer version on my 08 Z06 that is better, but not excellent. They both work very well at getting the cold air in, especially at speed. Too bad we have to cut the radiator shroud to get them in.
If the shroud is a deal killer, look real hard at the Halltech Killer Bee II
Old Aug 20, 2011 | 12:32 AM
djbrun's Avatar
djbrun
Actually the super bee is made to eliminate erratic idle and surge. (MAF position is changed) I upgraded from my killer bee II and it idles just like stock if not better. So, if you are going with Halltech I would suggest the super bee.
DJ
Old Aug 20, 2011 | 12:42 AM
SilvrVette's Avatar
SilvrVette
I have a K&N. Its part of a larger plan. The products like Varram that have you cutting up your car to get "cold air" are IMHO bogus. You won't see a "ram effect" before you see blue lights in the rear view. And how "cold" is air 5" off an asphalt surface that can fry an egg in the summertime ? BTW - I used to wind tunnel test sports cars in college.
Have fun. Get one that's quality made and affordable to your budget. You can always upgrade.
Old Aug 20, 2011 | 01:39 AM
haljensen's Avatar
haljensen
He asked about Cold Air Intakes.
K&N is not a CAI.
K&N makes CAI's for many cars but the C6 Corvette isn't one of them. Unless you cut the shroud or allow outside air to the filter some other way you don't have a CAI, you have a replacement filter/airbox.
Old Aug 20, 2011 | 01:56 AM
SilvrVette's Avatar
SilvrVette
K&N is not a CAI.
Agreed. But where you going to put it? In the wheel well like a Rustang? "cold" is relative. I would like to see temp data taken at the intake compared to ambient at highway speeds. I seriously doubt there's an appreciable difference.
Old Aug 20, 2011 | 08:16 AM
dealer06's Avatar
dealer06
I'm no scientist, but (in response to SilvrVette) surely air at even fairly hot asphalt is cooler than the air inside a hot engine bay?
I'm thinking if I ever get my exhaust worked out, intake will be next, so I'm curious. On my "to do" list this weekend was "comb through Corvette Forum threads on CAI," so I'm interested.
Old Aug 20, 2011 | 09:22 AM
haljensen's Avatar
haljensen
Cold is relative, agreed but by your reasoning the stock C6 filter setup is a CAI also. Maybe a better term would be Fresh Air Intake (FAI)? Instead of air thats been thru the radiator and over, around and thru the engine compartment like the stock setup.
Old Aug 20, 2011 | 10:06 AM
JoesC5's Avatar
JoesC5
Actually, if you took the time to carefully examine a C6 you will find that the compartment surrounding the air breather is not sealed at the bottom, on each side, and allows air to enter from the bottom of the car at the front of the car and through the grille. The air does not pass through the radiator and over, around and thru the engine compartment to get to the air breather as you state.
The compartment that the air breather resides in, is open at the top and when at rest, radiant air from the engine compartment can heat the air breather compartment, but as soon as the car is in motion, air enters from each side of the grille before it passes through the radiator, and also from under the car, at the front.
On the GS/Z06/ZR1, with the duct at the top of the front bumper, additional "cold" air enters the air breather compartment, to supplement the air entering the air breather compartment from the bottom.
Old Aug 20, 2011 | 10:49 AM
Boomer111's Avatar
Boomer111
I wouldn't change it. I had light surging with my CAI and not legal here in Ca. If you do change though it should be to a true cold air intake design for any benefits over the oem intake.
By the way the stock filter is the best in the market and good for 50,000 miles and the LS3 breathes just fine. But the cooler air will let you tune with more timing. Maybe only good for repeated runs at the strip or track laps.
Old Aug 20, 2011 | 10:53 AM
OctaneHi's Avatar
OctaneHi
Halltech!!!!!
To Cold Air Intakes
Old Aug 20, 2011 | 11:00 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I've tried numerious intakes on C5 and C6. The CAI produce better results on the LS1 and LS2 platforms. GM greatly improved the intake on the LS3/7 and LS9, and gains on the newer motors are minimal.
My opinion, don't waste your money on a CAI, and especially if you are not going to tune your car. Of course vendors are going to boast numbers, they have to in order to selll their product. I am not stating they don't work at all, but for the money you spend vs. the power you will pick up, not worth it.
If you are planning big mods like a cam/heads /headers.. maybe it is more beneficial..but with minor mods its a waste of $$$
Halltech (with beehive incluced) Vararam, Callawy Honker are all True CAI as they draw in cold air and do not expose the filter to the heat soak in the engine bay. K&N, Blackwing and the others are not CAI as they leave the filter sitting out in the engine bay exposed to all that heat soak.
Many have modded the stock GM intake on the GS and Z06, the key is Cold Air... not the filter, it's getting cold air into the intake.
Old Aug 20, 2011 | 11:04 AM
Kensmith's Avatar
Kensmith
I have a Lingenfelter for sale that I had to remove to pass Cali smog. Check the parts for sale forum under my user name if interested.
Old Aug 20, 2011 | 12:32 PM
Luster's Avatar
Luster
