Problems Adjusting Ride Height
http://forums.corvetteforum.com/c6-c...uspension.html
As mentiond in that thread, the base shocks lowered the car by 5/16" in front and 4/16" in the rear; using multiple careful measurements. Since we use the car as a DD and road-tripper, I don't want it to be lower.
Yesterday I had the dealership adjust the ride height by using the GM measuring tool and also by verifying with marks I had made on tape on the fenders. According to the Service Manual, each turn on the adjusting bolts should raise the car by 2mm, so 4 turns = 8mm = 5/16". And by using full turns on the bolts, the rubber pads will have the same "set" angle on the springs, no need for them to settle.
After 4 turns and a short drive, the car was sitting so high it looked like a monster truck. The tech thought maybe he'd gotten something lodged under the rubber pads, so he temporarily backed 'em off and used the air hose in there. No change. So he backed off 2 turns on the bolts, still too high. He backed off one more turn, so now the bolts were only 1 turn higher than starting. Drove it for several miles and let it sit overnight. That seemed about right.
I took it another 5 miles home today and carefully measured the fender marks, the car is now 6/16" higher in the front and 5/16" higher in the rear, which means it is currently 1/16" higher, front and rear, than before I changed the shocks. That's close enough for me.
But, why is the effect of turning the bolts so much different from what the manual says? We both checked again, the Service Manual says that 1 turn on the bolts = 2mm change in height. But it seems like 1 turn is at least 8mm, that's a big difference. Especially since the set angle on the rubber pads has not changed, so they shouldn't need to settle in.
In one sense, I don't really care. But, I want to get an alignment done soon, and if the car is going to settle by another 6mm, then I should wait. But how long to wait? I'd think that 24 hours + 10 miles of driving, should be enough. Do I wait another day, or week, or month? Drive it a lot and hope I don't mess up my tires?
BTW, I believe CF member "Vet" experienced the same issue of 1 turn = way too much, but I never heard if his car settled more over time. And no one else I have seen has mentioned the problem.
Any experience out there?
And take a log of where it is now, or tomorrow morning and see where it is (if it's changed at all) after that next 20 miles. Then, I'd say you're ready for your alignment.
I do need mine raised a bit, too.
Today we put another 70 miles on the car, including some rather rough and undulating back roads. Preliminary measurements suggest it dropped another 2/16". I'll wait until everything cools off, then get more precise numbers.
You must have changed more than the shocks. New bushings maybe? I swapped out my Z51 shocks for base shocks which look identical but have different part numbers, and used all my original hardware so just the shocks were changed. I also did careful measurements before and after (put about 20 miles on the car for the after measurements). The measurements were exactly the same.
The bigger issue seems to be that it takes more than a day and a dozen miles, for the system to settle to its new ride height after an adjustment on the bolts.
But what's not good is that the measurements seem to change depending on how warm the car is. I didn't think that ~3 psi more in the tires, after driving, would make any difference. But i took the numbers this morning, drove 5 miles into town at ~40 mph, stayed for a while, and when I got home the car was about 2/16" higher.
Since I can't recall how warm the car was when I did the original measurements, that is perplexing.
Now I'm trying to decide whether to trust the GM Trim Height tool and try to set by that, or raise it one more turn (2 turns total), or just leave it alone.
Decisions, decisions...
1mm movement at the bolt (a foot from the pivot point?) could equal 3mm at the outside of the tire (3 feet from the pivot point?).
Jim, is the ride height difference both front and rear? if it is, somehow I'd doubt that there is spring damage. jm guesswork tho.
No, I was just trying to clarifying that simply changing the shocks would not affect the ride height.
If the ride height had changed, OP stated car now sat lower, it would seem to indicate that the shocks that were pulled out were too long and acting like a spacer for higher ride height. Also that the ride quality would be harsh because there was no shock action because they were already fully compressed.
And while I agree with "Rusty B." about what controls ride height, I do know for a fact that different shocks have/produce different ride heights, i.e., Koni FSD shocks tend to drop ride height up front by anywhere from 1/4"-1/2"+. Very possible that those Konis are a different length, end-to-end tho. Of that I am not certain.
Changing shocks should not change the ride height, but putting softer shocks in a Z51 car (like I did) has been reported to lower the car about 1/4" or more as reported by several other members here. That's what I experienced also. The best theory is that because the Z51 shocks have very strong gas pressure and it takes a lot of force to compress them for installation, they do in fact slightly support the car. I am confident that my measurements before and after the shock change were accurate (same car/tire/garage temperaturre, multiple measurements). Installing the base shocks lowered my car 5/16" in front (both sides) and 4/16" in back (both sides), measured to a mark above the wheel wells.
The original Z51 shocks were definitely allowing the suspension to move properly, just too stiff for the crummy roads in Illinois.
Springs were inspected also- no damage.
The Service Manual wants us to use the J 42854 Trim Height Measurement Gage, and i got one. But the tech who used it said there is enough slop in the tool attachments that he's not fully confident in the numbers, he said it's a good "ballpark" measurement. I've been using marks on the fenders because that allows me to easily check the difference from before. But the differences due to temperature (I think) are confusing that situation.
GM says that one turn of the adjustment bolts changes the trim height by 2 mm, but haljensen pointed out that's not the same as ride height measured at the fender; nice catch! Looking at the distances involved, it should be closer than I've been getting but i didn't measure the relationships.
If not, I'll have him raise it one more turn (two turns total) and drive it a bit, then get an alignment. We ain't building a swiss watch!
