Glass top cracking?
Old Aug 27, 2011 | 08:23 PM
spongebob777's Avatar
spongebob777
Default Glass top cracking?
I have some fine lines on my glass top.They were not there when i bought the car 3 months ago.Is there anything i can do to keep them from getting worse?
Old Aug 27, 2011 | 08:25 PM
b4i4getit's Avatar
b4i4getit
If its a new car then warranty will handle it. By the way its not a glass top its plastic.
Old Aug 27, 2011 | 08:33 PM
spongebob777
It"s an 06 so no warr
Old Aug 27, 2011 | 09:17 PM
RHFD122's Avatar
RHFD122
This past winter (2010) my 2006 Vette also began with that same problem. I took it to my local Chevy dealer and they said GM would have only covered it within the first 3 years or 36,000 miles. My Vette has only 19,300 miles but 5 1/2 years old.
I have been advised that the plastic will be sound and will not break with the spidering cracks. My spidering cracks is only on the drivers side. That plastic is the same material that the military uses in their fighter jet cockpits.
Regards
Old Aug 27, 2011 | 09:29 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
No one has found a way to stop the "crazing" once it starts, but you can help it from getting worse by avoiding large abrupt temperature changes (squirting COLD water on a hot top), and especially by avoiding most chemicals. Many window cleaners can cause this problem, the GM Glass Cleaner (white foamy stuff in a spray can) works well on plastic or glass.
Kwagnerhvac's Avatar
Kwagnerhvac
Are they actual cracks that you can feel or is it spider cracks inside the plastic?
Old Aug 27, 2011 | 10:02 PM
not08crmanymore's Avatar
not08crmanymore
Well,being that you're out of warranty why don't you try a glass place that fixes small cracks in windshields??They may be able to help.
Old Aug 27, 2011 | 10:33 PM
speedraider's Avatar
speedraider
This is why I use my painted top in the summer and clear top when it cools down. These clear tops can't handle the heat.
Old Aug 27, 2011 | 11:57 PM
RtStuf's Avatar
RtStuf
How do you know this? What causes the crazing?
Old Aug 28, 2011 | 12:21 AM
Redbarchetta's Avatar
Redbarchetta
Cruising
I have an 08 coupe that I bought in April that was still in warranty, so I just got a replacement. There was no crazing (spider cracks) in the top when I bought it and it got really bad in the few months I owned it and was fortunate enough to get a new one. Now I have a theory on how they developed that may help avoid them getting worse. It seemed that the crazing got worse the more I removed the top and handled it when it was hot. I live in the South and the temp of the roof in the heat of the day can get pretty high, so as you remove the roof from one side, the uneven loading from how you hold it c
Old Aug 28, 2011 | 12:30 AM
Redbarchetta
Cruising
....can cause the plastic to develop micro cracks...this is just a theory from a mechanical engineer, but I plan on only taking the top off when it is not heated by the sun.
Old Aug 28, 2011 | 12:40 AM
Timothy409's Avatar
Timothy409
There is a service bulletin number 08-08-67-001 on this problem. I had the top on my '06 replaced under this. I don't know if they will honor it after warrenty has expired but it might be worth a try to bring it to their attention. ( See thread "anyone else mysteriously get cracks in their roof" posted by Vettedaddy on 3/4/07 )
Old Aug 28, 2011 | 01:14 AM
George Ware's Avatar
George Ware
I had cracks on my 08 after a year. GM replaced it under warranty.
George Ware
Old Aug 28, 2011 | 02:33 PM
Gearhead Jim
St. Jude Donor '13
Unfortunately, it's almost impossible to be sure what caused the crazing in any particular case. But speaking generally-
Window cleaners that are not specifically formulated for plastic use, have a long association with crazing in plastic windshields on light airplanes. We have also had reports of this problem with Corvette tops.
I've also seen reports of sudden temperature change causing crazing in clear plastic.
Since "Association is not causation", we can't know for sure what caused the crazing in these cases. But the association is strong enough that I avoid the issues (most glass cleaners, cold water on hot top) and have put about 10 years/150k miles on three Corvettes with only the transparent top, none of them developed any crazing while I owned them.
Just trying to load the dice in my favor.
Old Aug 28, 2011 | 02:37 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I can't understand why they use plastic for the tops.
I owned a 89 Turbo Trans Am with removable T-Tops ... They were glass panels and not plastic.
Obviously, I never had a problem with those tops.
Old Aug 28, 2011 | 02:43 PM
Gearhead Jim
St. Jude Donor '13
A one-piece glass top would be pretty heavy. Difficult to remove/install, and adds weight up high to the overall car. Probably more expensive, also.
A two piece top would be easier to handle, but I really disliked the center bar on our '98 Camaro T-tops.
Weight and cost are the two things Corvette engineers are always trying to reduce.
Old Aug 28, 2011 | 03:10 PM
spongebob777
Thanks everyone for the responces.I have never put any cleaner on the top i did put some wax on it.I do live in Fl so it is very hot when i got the car.I do like taking the top out when it is hot.Well it's not a big deal was just seeing if there was anything i could do.
To Glass top cracking?
Old Aug 28, 2011 | 08:00 PM
joec's Avatar
joec
ya, I'm pretty pissed that my 08 top is doing this also... Obviously out of warranty and I don't think my extended warranty covers it.. Shame on GM... I've never used anything on it to cause this either..
Old Aug 28, 2011 | 09:06 PM
Gearhead Jim
St. Jude Donor '13
My previous, too-wordy, posts; were trying to say that some things seem to increase the likelihood of problems, but sometimes the darned tops just seem to go bad all by themselves.
Old Aug 28, 2011 | 11:32 PM
RtStuf's Avatar
RtStuf
Thanks for the response...is the clear top one layer or two?
