IPhone interference
Old Sep 2, 2011 | 08:00 PM
todm's Avatar
todm
Default IPhone interference
I know that an IPhone will interfere with the FOB which can result in the computer not recognizing it. The question I have is when turning the car off, is it possible that it will interfere enough so that the computer does not shut off and the result ends up being a drained battery?
Old Sep 2, 2011 | 08:04 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
First of all, you know this first part how? I have an iPhone and it has NEVER interfered with my Vette or my wifes......... EVER.
Old Sep 2, 2011 | 08:20 PM
todm's Avatar
todm
If I put my IPhone next to my FOB, there are tines when my will not be detected. There are also times when I turn off the car and I get a message of RUN and something else, can't remember.
Old Sep 2, 2011 | 08:24 PM
rz2mbc's Avatar
rz2mbc
have had 3 I-phones, never have had a problem
Old Sep 2, 2011 | 08:26 PM
RekaRoyal's Avatar
RekaRoyal
My iphone 4 blocks my fob if they're in the same pocket.
Simple solution. Don't put them in the same pocket.
Old Sep 2, 2011 | 08:27 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
No issues in my three years in our Vette and iPhone
Old Sep 2, 2011 | 08:28 PM
Don-Vette's Avatar
Don-Vette
iPhone no problem here either.
Old Sep 3, 2011 | 12:29 AM
Cyber2010's Avatar
Cyber2010
My iPhone is forever on my person and I've never experienced any issue.
Old Sep 3, 2011 | 12:41 AM
brooklync5's Avatar
brooklync5
I have an iPhone and have never had an issue
Old Sep 3, 2011 | 01:05 AM
WMark's Avatar
WMark
St. Jude Donor '11
Don't have an iPhone, but know certain cell phones and/or in car charging will mess with the FOB.
Road trip, this summer... In IL and stopped the car. Message came up, something like, FOB Not Dected. Off or Run. Anyway something like that. And I know!! I haven't looked it up in the manual!
So, stuck the FOB in the slot, and car started. Drove a while, stopped, same message. Did this a couple more times.
Near a dealer, so thought I would stop and have it checked. Made a call to a friend. My cell phone had been charging through the console outlet. The FOB was in my right pocket.
Before I got to the dealer, I disconnected the phone. When I got to the dealer, couldn't reproduce the problem. FOB worked great! Their Corvette tech and I finally figured it out...
FOB in right pocket, cell phone charging through console, NO FOB. Disconnect charger, no problem. Believe me, we tested it multiple times. Results were always the same. Charger in, no FOB. Charger out, no problem. Solution was to keep the FOB in LEFT pocket, or in storage bin on driver door when charging my cell phone.
Ain't makin' it up!!
Old Sep 3, 2011 | 02:52 AM
y2kvette's Avatar
y2kvette
my iphone will mess with my car, i have to take care where my iphone is placed and its not near the FOB that's for sure
Old Sep 3, 2011 | 05:29 AM
keyplyr's Avatar
keyplyr
Originally Posted by RekaRoyal
My iphone 4 blocks my fob....
Originally Posted by y2kvette
my iphone will mess with my car...
Through that piece of junk in the dumpster and get an Android
Old Sep 3, 2011 | 07:02 AM
Don-Vette's Avatar
Don-Vette
Old Sep 3, 2011 | 08:16 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Always have my iPhone when I drive the C6. Never had a problem. To answer your question, No, pushing the button will initiate a search for a FOB to decide whether the shutdown is done immediately or the shutdown must be confirmed if no FOB is found. In either case you are allowed to stop the engine. Once the engine stops the rest of the shutdown proceeds without need of looking for the FOB again. Ever since the 2005's had a problem with the DBS and the shutdown procedure was modified there is nothing that will drain the battery except having a weak battery to begin with.
Old Sep 3, 2011 | 08:22 AM
aceZ06's Avatar
aceZ06
^^^^^^^^^^^ This
Old Sep 3, 2011 | 09:25 AM
Daekwan06's Avatar
Daekwan06
Never kept my iPhone and FOB in the same pocket. Never had a problem. Seems to be your answer.
Old Sep 3, 2011 | 10:15 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I never had a problem with my iPhone interfering with my fob either. And I installed the GM PAL I got for Kawal. Works great, just not very loud. However that is another topic!!!
To IPhone interference
Old Sep 3, 2011 | 10:24 AM
KABAL182's Avatar
KABAL182
I have a iphone and i put the fob and phone right in the cup holder next to eachother with no issues at all. Guys with problems are your Iphone 's naked no covers/or plastic cases around them? The antenna is the metal frame around the whole phone the whole iphone reception problems were because of that, and apple sent out free covers to there customers to correct the reception issue.
Old Sep 3, 2011 | 12:00 PM
cclive's Avatar
cclive
But to answer the actual question, no...once you turn off the car, the i-phone will not make a problem. It may keep the fob from being recognized at startup or shutdown but once shut down, it will have no effect on the computer. In spite of many who have had no interference problems, cellphones causing problems with fobs is a known issue.
Old Sep 3, 2011 | 01:36 PM
tim414's Avatar
tim414
St. Jude Donor '12
x2
