good luck. It took me a couple hours to program a new fob. Persistence counts for this one. I don't even know how i did it but it finally came up on the dic after many tries.
It is the car that remembers the FOB, not the FOB remembering the car. The FOB identity is permanently a part of the FOB electronics.
If the FOB doesn't work in the glove compartment you have somehow managed to farkel the FOB. That isn't easy but with the case open and power floating around... In that case it wouldn't matter how the car programs a new FOB, the existing FOB is dead. Now if your other FOB has stopped working also then the car has been farkeled.
I'm betting you bought a bad battery. It happens occasionally. Remove the battery and try the glovebox again with no battery in the FOB shorting it out.
A new expression is coined........"I farkeled my fob".....
Probably stupid on my part....but maybe you just have a bad....new battery?
Originally Posted by cclive
Other than destroying the fob, there's nothing you can do to it that will require re-programming to the car. There is something wrong with the battery installation. Have you tried your other fob and have you tried this bad fob in the glovebox slot with the buttons facing to the right? Your car may very well have trouble getting into the program mode...but that has nothing to do with this problem. Keep messing with the fob battery and connections. It is also possible that you got a bad battery.
Originally Posted by blaforce
Good luck. It took me a couple hours to program a new FOB. Persistence counts for this one. I don't even know how I did it but it finally came up on the DIC after many tries. Make sure you push the FOB all the way into the slot.
Originally Posted by boraxman
^^^^ this!
If I could get the damn car to go in programming mode that would be half the battle... no matter what I can't get the DIC to even acknowledge the turning of the key which has nothing to do with the FOB I am using or the battery in the FOB...
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
And what we are trying to tell you is that you have 2 problems. Your FOB(s) are not working AND you are having trouble with the key switch. Getting it into programming mode will do no good as long as the FOB is dead. Solve the FOB problem(s) first and at least you will be back to where you wanted to be by just changing a weak battery. You will have a drivable car. THEN you can worry about why it won't go into programming mode which most people will never have to do in the life of the car.
There are 3 parts to the FOB system - 2 FOBs and 1 car receiver/transmitter. If only one FOB doesn't work, that FOB has a problem. If neither FOB works then the car has the problem.
Ok well I have 1 good FOB and 1 FOB with a fresh battery that will not work...it was fine until the battery got weak now its worthless as I cannot get the car into programming mode. If my 2nd FOB went dead I would be f**ked. This is a ridiculous system.
As FortMorgan said above, they are separate problems. You are not in trouble because "now its worthless as I cannot get the car into programming mode", because programming mode will not help you with this fob. Because of the battery change, it is not working and even if you were successful in getting the car into the programming mode, that would not change the fact that this fob is not working right now. If you did get the car into the program mode, it is possible that something could go wrong and then neither fob would work...right now you are still OK with one good fob. Check the fob battery voltage while it is in the fob, make sure the contacts are touching correctly and also try this fob in the glovebox slot with the buttons to the right.
Battery is good..checked and double checked, inserted correctly and zero response in the glovebox slot.
So explain to me what would happen if I bought a new FOB never been used and I couldn't get the car in programming mode?
That's the real issue..lets say for the sake of arguement this FOB is toast and I bought a brand new one...how would I program it?
I can't with the current system.
Basically this is going to require a trip to the dealer.
I think what everyone is trying to say is, you should not be trying to get into programing mode. You have one good fob. The other fob does not work. Putting a new battery in does not require re programing. There is something else wrong with your fob and it's failure to work. Programing is not the answer. Have someone else look at your fob tha has a clue.
There are many pages in that thread of tips from others for getting the car into the program mode but ultimately, if they don't work, then the dealer is the last resort. If you end up taking it there, you have a choice. They can either force program the newly purchased fob with a TECH II tool without touching the metal key, or they can repair the system so that it can be put into the program mode by turning the metal key in the trunk lock. Make sure that you understand which one they are going to do...as it would be bad to want to use the program mode a year or two down the road and find that it can't be done yourself. I know it's alot of reading, but there are many many tips that have worked for others there...patience required.
Spend some time tomorrow inspecting the FOB where the battery is placed to make sure that all of the contacts are clean and connected to the circuit board. I have seen FOBs that worked fine until a new battery was installed and upon inspection I found the solder joints for the contact the battery sits on were loose so it was just like there wasn't any battery in the FOB. Dealer will sell you a new FOB and charge you for diagnostics but you might just be able to avoid that if you check to see if everything in the FOB is in good shape. If it isn't, it might only take a few seconds with a low wattage soldering iron to fix it.
Ok here we go again.....after this thread I said "Fk it" chucked the POS in the drawer....about a week later I pulled it out and went to the car it worked fine.....nothing else changed. Now here we are again and it doesn't work The car doesn't recognize it...again.
And, at the risk of repeating myself, there are 3 parts to the FOB system - 2 FOBs and 1 car receiver/transmitter. If only one FOB doesn't work, that FOB has a problem. If neither FOB works then the car has the problem.
Find and fix the problem component and life will be good again. Programming isn't the issue, a failed component is.
I assume the other FOB works? If so, try swapping the batteries between them. New batteries being bad is not at all unknown.
Could the connection tab/terminal been damaged during the battery change? One of the techs at my dealer advised me that is possible to do, hosing the FOB in the process.
battery is good, It appears if a new FOB is obtained, then it will not be able to be programmed as the program mode on the car will not work
