Where can you buy cross beam adapters?
Received 2,225 Likes
Not with the short 2 X 4. The main reason for using the wood block is so that the jack doesn't nick or gouge the crossbeam and it distributes the weight over a larger section of the beam than the jack alone. A gouge might not hurt you in the short run but could be an initiation point for a fatigue failure in the future.
Does the Summit Racing cross beam adapter have a threaded hole in bottom of the center plug that fits inside the jack?
I also viewed the Greg Smith Equipment cross beam adapter on line and noted that it does have a threaded plug.
Want to use my Craftsman 2 1/4 ton jack, rather than purchase a more expensive jack as mentioned in this forum, but wanted to know if the Summit adapter center plug is threaded and its diameter, before I purchase the adapter.
Since each end of the car weighs about 1,600 pounds, I would expect a 2x6 to flex so much that most of the weight would be supported by the center of the crossmember at the jack pad itself; the extra pads on the end only account for 1.5" of flex.
How does yours look when you life the car?
I get about 1/16" flex in the 2X6. Even if the 2X6 flexed more then that, it will contact the center of the aluminum crossmember on the frame, preventing the 2X6 from breaking. With 1/4" thick plywood pads, that the maximum the 2X6 can flex. Use 1/8" plywood pads, and the 2X6 will only fgex a maximum of 1/8".
Received 2,051 Likes
St. Jude Donor '13
I use the 2X6, long enough to span the GM recommended lifting points on the cross members, with 5.5" X 5.5" pads on each end. I also have a pin mounted in the center, so I can remove the lifting cup on my floor jack, and the pin will drop in the hole in the jack. That way, no way can the 2X6 slip off the jack.
Thanks, I wasn't sure how much flex the 2 x 6 could take before cracking.
SUBVETTE
I just use a 21" 4x4 for the front and a 25" 4x4 for the rear, both marked with the center line which I place my jack saddle under. No need to remove the existing jack saddle. Place the 4x4 on the saddle, line up to preferred jacking points and go.
Thanks for the compliment. There are a couple reasons why I dont want to tell you how and what to build these out of. The first is that I wouldnt be doing the fabrication and dont want even the faintest thought of liability if you build them and somehow you get crushed by a car. The second reason is that this is a business of mine and it is my design albeit a simple one. You can see a lot in the pictures, but I am not suggesting you use them to make a set.
