Does this look normal??
Old Sep 27, 2011 | 02:51 PM
wayback's Avatar
wayback
Originally Posted by RoadVettes
Is there a way to tell if the end links are bad? I have a rattling noise in my front end when I go over bumps or even when the car vibrates a little, like coming off the clutch without applying enough gas.
Pull one off and check it out. It will be very loose it it is bad.(like a bad ball joint) Only 2 nuts to remove.
Old Sep 27, 2011 | 04:50 PM
BillH2121's Avatar
BillH2121
Originally Posted by wayback
They make a clunck. Even sometimes sounds like it comes from rear of car. Went through 2 sets of GM endlinks, now have LG heavy duty quiet end links. Much better!!
^Agreed - the first few times that mine popped, I thought I had run over something and it was hitting the bottom the car - its a definate clunk or low pop. As they get more more worn, you can make them pop by driving over uneven pavement slowly or turing slow turns.
Old Sep 27, 2011 | 06:45 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Originally Posted by Xedes
Endlinks gets my vote too.
Ditto
Old Sep 27, 2011 | 06:54 PM
cmonkey713's Avatar
cmonkey713
Based on what you have described it sounds like the end links are toast. Easy fix, great DYI project.
Old Sep 27, 2011 | 08:23 PM
Marc V.'s Avatar
Marc V.
Originally Posted by kb13kb13
Well I wrote to the service manager at the chevy dealership where I usually take my car and he didn't sound very convinced of sway bar end links causing a rattle/clunk. He seemed to think that would cause more of a squeak. Here's his response:
"Sway bar bushings tend to just squeak when worn, so if it is a clunk felt in the floor pan over bumps, the first thing I would check would be the exhaust hitting under the car. There could be steering or suspension or brake problems, drive shaft or u-joint problems, or any number of things. The other things would usually have associated complaints such as "I get this when I am turning right up a slight incline" or ad infinitum. If you would like to drop it off again some day, I am sure one of our technicians could figure that rascall out for you."
Hmm.... Is it bad to have more confidence in total strangers that are members of this forum than I do the service manager at the Chevy house?? Uggh.....
He sounds completely incompetent. Sway bar BUSHINGS and END LINKS are not the same componant. Bushings will squeak, but end links will clunk, knock or rattle.
Old Sep 28, 2011 | 01:10 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
kb13kb13 – if you do decide to go to the dealership, please let me know so I can make sure everything is taken care of. If you have any other questions feel free to send me a PM.
Thanks,
Laura
GM Customer Service
Old Sep 28, 2011 | 02:16 PM
kb13kb13's Avatar
kb13kb13
I went ahead and took my car to the dealership this morning to have them look at it.
Within an hour and a half of dropping it off they were already calling me with the diagnosis. Was just as what most of ya'll were saying... the sway bar endlinks were bad. They're putting new ones on the front and back. So problem should be solved! But I'll post for sure once I actually get it back and drive it around a little bit.
PS-Thanks again to everybody who posted and shared their opinions and info with me. A HUGE help!
Old Sep 28, 2011 | 03:20 PM
VET4LES's Avatar
VET4LES
Good news. Keep us posted.
Old Sep 28, 2011 | 03:25 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
doesn't it make you feel good when you can educate the entire service department of a dealership from those same "anonymous" persons on a Corvette Forum? AND get the car (hopefully) serviced correctly?
wow, what a win-win situation.
Old Sep 29, 2011 | 08:07 PM
Marc V.'s Avatar
Marc V.
Old Sep 29, 2011 | 09:54 PM
Mad*Max's Avatar
Mad*Max
Old Sep 30, 2011 | 08:07 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Just make sure you check for broken rocker panels before you leave.
Old Oct 1, 2011 | 06:45 AM
  #33
VET4LES's Avatar
VET4LES
Has it been fixed yet?
