Does this look normal??
Old Sep 26, 2011 | 06:00 PM
kb13kb13's Avatar
kb13kb13
Default Does this look normal??
Ok, first let me apologize for my lack of correct terminology. I'm extremely clueless when it comes to the majority of car parts and their names and functions. Anyhow...
I have a 2008 Coupe with 40K miles on it. There is an obvious rattle/clunking noise that come from the underside of the car somewhere near the front on either side. This occurs any time I drive on any surface that's anything less than completely smooth. I can feel the thud in the floor board underneath my feet a little bit. I had a friend look under my car today and he took this pic (and I'm sorry, but I have no clue which part this actually is.. hoping you guys might recognize it enough though to possibly give me some feedback)
Does this look normal? Or is there a nut or something missing betweening these parts. There's a bolt there that's threaded, which usually calls for a nut being in place (i think?)
[IMG][/IMG]
Old Sep 26, 2011 | 06:02 PM
el es tu's Avatar
el es tu
the spring is supposed to look that way
The cars height is adjusted with that bolt
something else is loose or worn...
good luck!
Old Sep 26, 2011 | 06:06 PM
chris12.8's Avatar
chris12.8
normal for some hehe.
Old Sep 26, 2011 | 06:07 PM
bklyn vette's Avatar
bklyn vette
the pic looks normal however....the clunkin noise you are describing is usually bad endlinks on the sway bar...
Old Sep 26, 2011 | 07:26 PM
EVRose's Avatar
EVRose
Old Sep 26, 2011 | 07:39 PM
RicK T's Avatar
RicK T
Yea, I'm betting the end links are bad. Pretty common issue.
Old Sep 26, 2011 | 07:48 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Looks like the lowering adjusting bolt is missing the rubber pad
Old Sep 26, 2011 | 08:24 PM
Boltfan555's Avatar
Boltfan555
St. Jude Donor '12
Old Sep 26, 2011 | 08:38 PM
Xedes's Avatar
Xedes
Endlinks gets my vote too.
Old Sep 26, 2011 | 08:56 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I think the pad is there ok, just partially obscured by the part in the bottom of the pic.
Old Sep 26, 2011 | 09:18 PM
Marc V.'s Avatar
Marc V.
Old Sep 26, 2011 | 09:30 PM
VET4LES's Avatar
VET4LES
The above suggestions are possibilities. If you can feel it under your feet another place to look is the spring that holds the exhaust system in place. If not adjusted properly it can make a loud thud. It happened to me.
Old Sep 27, 2011 | 09:54 AM
kb13kb13's Avatar
kb13kb13
Thank you guys for your help and ideas! Much appreciated!
Old Sep 27, 2011 | 10:09 AM
SouthernGuy85's Avatar
SouthernGuy85
Sounds like the end links, had the same problem. Luckly, its not to expensive to replace. The local GM dealer had my C6 ready in one day!
Old Sep 27, 2011 | 12:30 PM
BillH2121's Avatar
BillH2121
Or.....they are really easy to replace yourself and save some $$$$!
Old Sep 27, 2011 | 02:10 PM
RoadVettes's Avatar
RoadVettes
Is there a way to tell if the end links are bad? I have a rattling noise in my front end when I go over bumps or even when the car vibrates a little, like coming off the clutch without applying enough gas.
Old Sep 27, 2011 | 02:41 PM
kb13kb13's Avatar
kb13kb13
Well I wrote to the service manager at the chevy dealership where I usually take my car and he didn't sound very convinced of sway bar end links causing a rattle/clunk. He seemed to think that would cause more of a squeak. Here's his response:
"Sway bar bushings tend to just squeak when worn, so if it is a clunk felt in the floor pan over bumps, the first thing I would check would be the exhaust hitting under the car. There could be steering or suspension or brake problems, drive shaft or u-joint problems, or any number of things. The other things would usually have associated complaints such as "I get this when I am turning right up a slight incline" or ad infinitum. If you would like to drop it off again some day, I am sure one of our technicians could figure that rascall out for you."
Hmm.... Is it bad to have more confidence in total strangers that are members of this forum than I do the service manager at the Chevy house?? Uggh.....
To Does this look normal??
Old Sep 27, 2011 | 02:47 PM
Neil Baker's Avatar
Neil Baker
Old Sep 27, 2011 | 02:49 PM
wayback's Avatar
wayback
They make a clunck. Even sometimes sounds like it comes from rear of car. Went through 2 sets of GM endlinks, now have LG heavy duty quiet end links. Much better!!
Old Sep 27, 2011 | 02:51 PM
EVRose's Avatar
EVRose
You could get under the car and check them and see if they knock around. This is what they look like.
