TPMS - How accurate?
Old Sep 30, 2011 | 10:54 PM
  #41
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Originally Posted by BEZ06
ALL gases change volume, or pressure if constrained in a constant volume vessel such as a tire.
Nitrogen is a gas, therefore it complies with ideal gas law and the laws of physics and thermodynamics.
However, commercially available nitrogen has been processed so that when bottled it is virtually completely dry.
Atmospheric air is 78% nitrogen, but there is also water vapor in humid air that probably affects the pressure change due to variations in temperature to a greater extent than when the tire is filled with dry nitrogen, or any other dry gas.
So....a tire filled with nitrogen will experience pressure changes due to changes in temperature, or ambient atmospheric pressure, just like any other gas.
Bob
do you mean to say that:
PV = nRT ?
Old Sep 30, 2011 | 11:05 PM
  #42
BEZ06's Avatar
BEZ06
Originally Posted by need-for-speed
Why shouldn't they agree? Are they using different technology? I live near sea level and mine reads about 2 psig low too.
Conroe is about 200 feet above sea level.
However, on a 95 degree day the density altitude can be 2,700 to more than 3,000 feet, depending on the humidity and barometric pressure setting.
That means that the ambient atmosphere you're driving around in is exactly the same as if you were at around 3,000 feet in elevation on a standard day.
So.....in the summer time in Conroe you're going to see DIC pressures a couple psi lower than your handheld gauge reads.
Butt.....maybe there's a hint of fall in the air down in Conroe, so soon the temps should be down, which will lower the DA, and your DIC should get closer to your gauge pressures as your temps get down to a standard SL temp of 59*.
Bob
Old Sep 30, 2011 | 11:15 PM
  #43
phileaglesfan's Avatar
phileaglesfan
Bob
Not as much though. Compressed air is not as "pure" as nitrogen.
Old Oct 1, 2011 | 01:36 AM
  #44
rm50's Avatar
rm50
2020 C8 of the Year Finalist - Unmodified
My Grand Sport runs about 2 psi lower than my handheld gauge
Old Oct 1, 2011 | 08:57 AM
  #45
need-for-speed
CI 1-4-5-8-9-10 Vet
Bob
Thanks Bob. I wasn't considering absolute pressure vs gauge pressure.
Old Oct 1, 2011 | 09:11 AM
  #46
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
Mine read about 2 psi lower than my Intercomp and Michelin digital gauge. I know my Intercomp gauge is dead accurate.
Old Oct 1, 2011 | 09:33 PM
  #47
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Wonder if altitude affects the taste of chocolate chip cookies
Old Oct 1, 2011 | 09:47 PM
  #48
need-for-speed
CI 1-4-5-8-9-10 Vet
I have read where the delta between inside and outside pressures can cause priapism at altitude.
Old Oct 1, 2011 | 10:00 PM
  #49
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
The heck you say ................... Now that's down right scarey !
Old Oct 1, 2011 | 10:08 PM
  #50
Russell ZR1's Avatar
Russell ZR1
I am 13 feet below sea level, no I don't live in a hole, mines, yes I said mines, is 2 psi high compared to my professional digital handheld. I set mines at 28 psi to read 30 on the DIC...
Old Oct 1, 2011 | 10:15 PM
  #51
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
I was gonna say you had to be near the Salton Sea. Then I saw Indio, CA
Old Oct 1, 2011 | 10:24 PM
  #52
Russell ZR1
Yep, I think it's a few feet lower then we r, cause all the waste water/gray water goes there...it makes itself known from time to time by the smell, it's been angry this summer, pee yew...
Old Oct 1, 2011 | 10:52 PM
  #53
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Old Oct 2, 2011 | 11:08 AM
  #54
need-for-speed
CI 1-4-5-8-9-10 Vet
Ohhh nooooo
it's turd water !!!!
run !!!
Old Oct 2, 2011 | 11:14 AM
  #55
cclive's Avatar
cclive
In your situation, I would set the gauge at 30 and let the DIC show 32.
Old Oct 2, 2011 | 11:16 AM
  #56
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by JimTN
Mine's usually within 1 psi.
Mine too - both the Corvette and the CTS.
Old Oct 2, 2011 | 12:30 PM
  #57
Jimsan's Avatar
Jimsan
TPMS is 1-2 low on both the old GYs and new Michelins. Must be the altitude up here at a mile high.
To TPMS - How accurate?
Old Oct 2, 2011 | 01:02 PM
  #58
Russell ZR1
i've done that a few times, and found this was the best "compromise" for summer driving.
I ran into a hi pressure warning when i did 32, DIC 34, in the summer the tires increase 6-7 PSI as im driving around. tires shot up to 40+ PSI and triggered it. so i left it a bit on the low side just incase..
and Nitrogen would be good but the aftermarket 3 piece wheel leak a bit so they need to be topped off a few PSI every few weeks...
Old Oct 2, 2011 | 01:04 PM
  #59
Russell ZR1
Ohhh nooooo
run !!!
yea, pretty much, and you know people still go fishing out there,
i think they have an advisory posted, not to eat more then one fish per month from there....yuck...
Old Oct 2, 2011 | 05:18 PM
  #60
cclive's Avatar
cclive
To clarify a bit....the reason that tire pressure is important is mainly to make for good, even tire wear. For this purpose, the important pressure is the relative pressure, not the absolute. So the handheld tire gauge is the more important of the two. The inflated shape of the tire is what is important and this is determined by the relative pressure, not the absolute pressure.
