TPMS Problem! Ugh!!
Its a 05 C6 Base Model.. Not sure what to do here!
Best of luck.
The reason I ask is that I had an '05 that was built in July 2004. It had an early version sensor that was also used on the 2004 XLR.
My car, and other C6's built before about Sept 2004 will have those early sensors.
The early sensors can be triggered with a magnet instead of a TPMS tool.
Two of my early sensors responded to either a tool or a magnet, but the other two only responded reliably to a magnet.
So....if your car is a very early 2005 (built before about Sept 2004), try using a magnet on those front sensors durig the program procedure. You'll need the tool for those two new rear sensors.
BTW, did you see the new sensors??? If so, they should have been gray peanut shaped sensors wih GM part# 25758220. Is that what you got and what is installed in your rear wheels?
Did you see the old ones they removed from your rear wheels? If they were the gray peanut shaped ones, then your front ones are probably those ones as well. Those ones require a TPMS tool to trigger them.
If your old rear sensors were black square shaped sensors, then those are the magnetically triggered ones, and the front ones are almost certainly those type as well.
Good luck!!
Bob
A proper re-train should fix that. But if one of the sensors won't work to train, then I get confused.
Thanks,
Laura
GM Customer Service
BTW my '07 replacement is showing in delivery 8 now.
