tire recommendations
Old Oct 12, 2011 | 11:55 PM
rexracerx9's Avatar
rexracerx9
Do you do any driving events?
I know some people do not like the Supercar F1's. I wonder if they drove on the street only or on a track where you can heat up the tires. Personally I thought the F1's were pretty good tire once warmed up. I think most of the tires mentioned will have worst dry traction then the F1. A definite upgrade would be a Micheline PS2. Very predictable.
Old Oct 13, 2011 | 01:49 AM
Garibaldi's Avatar
Garibaldi
I've used Conti DWs, Firestone Wide Ovals, and Kuhmo SPTs. I was happy with each of them.
Old Oct 13, 2011 | 09:59 AM
larrysandy's Avatar
larrysandy
Firestone - 4 votes, Hancook - 4, Michelin - 3. I guess the gun is loaded and when I pull the trigger it will be one of the leading two, if for no other reason than cost of the Michelins. Firestone is run-flat, Hancook not. Is that worth the slightly higher $ diff.? I think perhaps stick with RF.
Old Oct 13, 2011 | 11:33 AM
ohmy's Avatar
ohmy
does anyone know of a "real" comparison chart on different brands? Like the OP, I'm trying to do research on what tire to get.
I'm mostly interested in figuring out a definitive answer to "which run flat tire has the best wear" (lasts longest).
I'll gladly sacrifice dry performance for longer wear, and wet traction...
Old Oct 13, 2011 | 11:44 AM
brooklync5's Avatar
brooklync5
Very very pleased with my hankook v12 evos
Old Oct 13, 2011 | 12:15 PM
Garibaldi's Avatar
Garibaldi
One of the basic ways to check on wear is to find the Uniform Tire Quality Grade (UTQG) on the side of the tire or in the specs. Tire Rack lists this in all their specs. The higher the number, all things considered, the longer lasting the tire. When you find one that fits that your needs, look at any reviews or roadtest for that tire. Also on tirerack.com. Finally, it's another general rule of thumb that All Season tires last longer than Summer Only, Performance, High Performance, and Ultra High Performance tires.
All the best,
GP
Old Oct 13, 2011 | 12:35 PM
mikeCsix's Avatar
mikeCsix
Here's another vote for the Michelin's. I ran both the GY Supercar's and the PS2's at the track this year, in all fairness this is my first season and started with the GY's. I replaced them with the SP2's for the final session of the year and was amazed at the difference. For the first time I never had to use the rear view mirror and lapped many other cars. I don't have an unlimited budget though and will upgrade to R-compound tires for track days as I don't want to tear up a set of $2500 tires every other year just running at the track.
Old Oct 13, 2011 | 01:33 PM
Bobbyosto's Avatar
Bobbyosto
Bridgestone Potenza Re 050 RFT: cheap and great mileage and performance; hot or cold.
Old Oct 13, 2011 | 03:48 PM
RGFrederick's Avatar
RGFrederick
7th Gear
Just replaced my Goodyear F1 runflats with Nitto NT555's this morning. Much improved ride, noise, and feel, however, they're NOT runflats and they're W rated. I typically don't drive too aggressively, except for an occasional romp. Haven't pushed them much, so can't weigh-in on an overall opinion yet. My initial impression is that they're a great tire for the $$$.
Old Oct 13, 2011 | 04:57 PM
66biskwik's Avatar
66biskwik
All the best,
GP
I was told that only works within tire brands and you can't compare
between brands since different brands use a different rating system.
Old Oct 13, 2011 | 07:10 PM
hig4s's Avatar
hig4s
I had Potenzas on my Acura and they were great, even in the wet, but then the Acura was 150hp less than my C6 and front wheel drive.
When the time comes I think I would like to stick with run flats, but still debating that, and seeing my car is new I have some time left to think about it.
Old Oct 13, 2011 | 07:49 PM
Garibaldi's Avatar
Garibaldi
I believe that is correct. I think, though, that it is a rough rule of thumb. If one tire is rated 180 and another is 360, then I'd be inclined to think that the 180s are going to be gumballs with high treadwear (fewer miles). Am I incorrect?
Old Oct 13, 2011 | 08:53 PM
  #33
66biskwik's Avatar
66biskwik
I would agree with you.
Old Oct 13, 2011 | 11:40 PM
  #34
Mickeyrx70's Avatar
Mickeyrx70
Default Tire wear rating
My understanding for UTQG is that any comparison is only valid for different tires within the same brand. A Michelin tire with a treadwear rating 220 may give you more miles than a General tire with a 400.
Old Oct 14, 2011 | 07:46 AM
  #35
nickli's Avatar
nickli
Hankook V12's Love them compared to the oem. saved some 4 too. just hope I dont get a flat bc thet are not run flats.
Old Oct 14, 2011 | 10:15 AM
  #36
Boomer111's Avatar
Boomer111
The UTQG system is a teaser for sure. What is needed is a system that is uniform across all brands.
Old Oct 14, 2011 | 12:56 PM
  #37
robertaj's Avatar
robertaj
Originally Posted by DSOMC6
Here's my take on street tires for the C6.
If money is no object: Micheline PS2's
If you are not a baller: Kuhmo Ecsta SPT's.
I've tried just about everything in-between the two tires (logged over 100k miles in a C6 since 2005) and found the Pilots to grip the best, for a street tire, but very expensive if you log a lot of miles.
The Kuhmo's are not expensive and grip decent for the money. ($240/rear & less for front OTD). Spending an additional $75-$100+/tire for something less superior to the PS2 (and no more traction than the Kuhmo) isn't worth it IMHO.
Funny I just HAPPEN to have a set of ps2's ZP with 08 polished 5 spokes for sale. ALSO comes with the TPMS sensors in the tires.
Tires have about 85% or so tread left. I went with a new set of rims/tires (non-runflats) once i supercharged my car. These tires are to expensive to spin the wheels with lol
I would sell them as a package for pretty much the cost of the tires. $1900 + shipping (or come pick them up) the tires alone on tirerack are 1895. So you get the rims/tires/tpms sensors all for 1900
To tire recommendations
Old Oct 14, 2011 | 01:14 PM
  #38
Elite275's Avatar
Elite275
Take a look at the Bridgestone RE-11's. I have them on mine in stock sizes and am very happy with them so far. Slightly less treadwear than some of the other suggestions but handle really well, good in the rain, and traction is very good.
Old Oct 14, 2011 | 05:56 PM
  #39
66biskwik's Avatar
66biskwik
What size are the tires?
Old Oct 14, 2011 | 06:13 PM
  #40
06 C6 vert's Avatar
06 C6 vert
Buddy of mine with a C6 just got the Non RF Continental 's and he likes them. But hes not into carving turns so he couldn't rate the handling on them.
