red air bag light
Old 09-12-2012, 01:52 AM
child_of_fire
child_of_fire's Avatar
please bear with me...im resurrecting this thread as i removed the seats, zip tied the sh-t out of the connectors, checked all wire connections and still have the issue. also it should be noted that the seats in my car are not power and no one else drives the car so basically the seat never moves forward or back or changes position. ever. my question to you folks is this...
i read somewhere that when the red air bag light illuminates at the dash it simply means that the air bag is disabled. i noticed that it only tends to come on when speeds are in excess of 100+... so in my research it was noted that the system deactivates at 130mph because an airbag would kill you at that speed if the crash alone would not. so logically this makes sense because the light goes out after the car is turned off and restarted and only seems to activate at the higher speeds as mentioned.
long story short, my warranty is up in october and i dont want to waste my time at the dealer if in fact the vehicle is working according to spec and the light is supposed to activate at the said speed.
anyone have any more insight?
thanks
Old 09-12-2012, 06:53 AM
Seadawg
Seadawg's Avatar
thanks
The dealer told me that there was no TSB, when I was experiencing the same issue with my '11 Grand Sport recently. They said mine had a code B0101, and when they checked out the front impact sensor, they said it was faulty, so they replaced it.
So far, no issues. Here was where I posted about it before, and there is more info that may interest you..... http://forums.corvetteforum.com/c6-c...bag-light.html
Old 09-12-2012, 07:06 AM
C7Joy
C7Joy's Avatar
No problem on the vette but I have the airbag light on my truck on and off all the time. A good bump or pothole will do the trick. I have fooled around with connectors to no avail. I just deal with it.
Old 09-12-2012, 09:06 AM
Ketchum
Ketchum's Avatar
The 2009 is NOT a 2005 to 2007. Those are ones most reported with pulled pins,connectors. See if any codes. That should be done first off.
Old 09-12-2012, 07:23 PM
child_of_fire
thanks dudes. do you think that a code is stored in the computer or do i have to show up with the light on?
and no one knows anything about the 130 mph deactivation thing? maybe its a rumor.
Onthat_Z06 (08-04-2019)
Old 09-12-2012, 08:20 PM
MKenM
Support Corvetteforum!
MKenM's Avatar
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
I have a '12 GS and the light goes on and off on its own. Many times I don't have to turn the car off for the light to go out. I will have to pay more attention to see if speed has anything to do with it.
Old 09-13-2012, 10:08 AM
Seadawg
Seadawg's Avatar
It "should" store a code, but the dealer tech service department will be able to tell your for sure.
I'm not sure if a "normal" code reader (like the kind they sell to plug into the OBDII connector) will display it, because they hooked up the "big machine" to my car when it was happening to me.
Old 09-17-2012, 03:49 PM
Gearhead Jim
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
Our 2006 went briefly to 165 mph and the airbag light did not come on.
Our 2009 went briefly to 161 mph and the airbag light did not come on.
Old 09-17-2012, 09:42 PM
MKenM
MKenM's Avatar
Over the weekend the light came and went numerous times. None were connected to excessive speed. Have to make an appointment with the dealer. More of a nuisance than any thing else.
Old 10-17-2012, 05:42 PM
robl45
robl45's Avatar
where exactly is the connector? I looked under the back of the seat bottom on drivers side today and didn't see any yellow connector. my light goes on and off too on my 2008
Old 10-17-2012, 05:48 PM
VET4LES
VET4LES's Avatar
It should be attached to the seat frame at the rear of the seat. Check out my picture earlier in this thread.
Old 10-17-2012, 05:51 PM
robl45
robl45's Avatar
I did, I saw nothing yellow, I'll have to look again, do I have to take out the seat for this?
Old 10-17-2012, 06:14 PM
  #33
The Director
The Director's Avatar
I have a '12 GS and this happens whenever I do full throttle takeoffs in 1st gear. It always seems to clear when I turn off the ingition so I haven't done anything about it yet.
Think I'll try the zip tie connectors thing.
Old 10-17-2012, 06:59 PM
  #34
Ketchum
Ketchum's Avatar
Bet its a issue in the seat.
Old 10-17-2012, 07:04 PM
  #35
VET4LES
VET4LES's Avatar
No. Move the seat as far foreword and up as high as it will go. You will see them at the back of the seat.
Egangroup1 (11-12-2020)
Old 10-17-2012, 07:45 PM
  #36
robl45
robl45's Avatar
i moved seat as far forward as it would go, but I didnt lift it up, I 'll try that.
Old 10-18-2012, 03:14 AM
  #37
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
Every time I've noticed the airbag light has come on was after exceeding 130 MPH. Joe G on this forum has a video of his airport one mile run and you'll see the airbag light go on at 130. YMMV
To red air bag light
Old 11-25-2012, 01:03 PM
  #38
MA ZO6
MA ZO6's Avatar
St. Jude Donor '13
I was out for a high speed run today on my 2010 GS and after I hit 150MPH ( first time in this car ) I noticed the airbag red light was on. When I turned the car off and restarted it the light stayed off.
Can someone confirm if this is normal operation at high speeds or if something is wrong with it?
My 2003 and 2007 ZO6 never did this and both cars saw speeds above 150MPH.
John
Old 11-25-2012, 01:49 PM
  #39
Gearhead Jim
St. Jude Donor '13
2006 coupe, A6, Z51, replaced by 2009 coupe A6, Z51
Have been to 150 a couple of times in each, and 160+ once in each. No lights or warnings of any kind.
Old 11-26-2012, 03:00 AM
  #40
child_of_fire
usually my comments here get me in trouble. and hopefully the mods dont interpret this comment as interfering with a sale of a chevy car...
anyway the car was brought to the dealer and both front air bag sensors were found to be faulty and were replaced under warranty... good thing because they are not cheap. they are the ones located behind the front bumper.
Quick Reply: red air bag light
