Quick question guys. Ive noticed that when Im hitting full throttle in 2nd gear in my 05 M6, It seems to not want to go into 3rd gear. Let me explain
Earlier, I was doing some spirited sprints. When I was gunning in 2nd and grabbed 3rd, the gear goes in but the car revs freely like as if it were in neutral. IT IS NOT in neutral because when I try to pull the shifter down, it wont go to neutral, but it isnt in gear either
Is this a problem I have or is it some jibberish vette saftey thing GM installed? thanks
On a related note. 3rd usually grinds/misses because of the angle we try to engage it. I can't 100% blame the driver (us) because everyone does it so there must be something awkward to the gate angle design. The best way to hit 3rd is to open palm it. Don't grab it like a baseball and push it in. That tends to make you push the shifter slightly to the right, just enough to get hung up. An open palm creates a more neutral straight upwards shift, which is exactly where you want it to go. Try that, see if it helps. If not, like I said, your synchros might be going. How many miles?
On a related note. 3rd usually grinds/misses because of the angle we try to engage it. I can't 100% the driver (us) beacuase everyone does it so there must be something awkward to the gate angle design. The best way to hit 3rd is to open palm it. Don't grab it like a baseball and push it in. That tends to make you push the shifter slightly to the right, just enough to get hung up. An open palm creates a more neutral straight upwards shift, which is exactly where you want it to go. Try that, see if it helps. If not, like I said, your synchros might be going. How many miles?
I can tell for sure that it is not this. Good luck on the resolution.
Yea I figured, but coming from driving mostly mustangs and cobras the last 5 years, some of the stuff I see on the vette labeled as "safety" is crazy...
On a related note. 3rd usually grinds/misses because of the angle we try to engage it. I can't 100% blame the driver (us) beacuase everyone does it so there must be something awkward to the gate angle design. The best way to hit 3rd is to open palm it. Don't grab it like a baseball and push it in. That tends to make you push the shifter slightly to the right, just enough to get hung up. An open palm creates a more neutral straight upwards shift, which is exactly where you want it to go. Try that, see if it helps. If not, like I said, your synchros might be going. How many miles?
hmmm, ok I will. But just to be more clear, this only happens when Im WOT in 2nd and trying to shift hard/fast into 3rd. Not power shifting, but just hard, like anyone trying to get up to speed ASAP.
This is a big problem with these cars, I am currently going through it with my ZR1, I hate it. To those who know, does the MGW shifter help this problem specifically?
The best way to shift into third is to let the centering springs do their job, then just slide the lever forward. Actually a fairly fast process and you want accidentally miss a gear. My car is the best shifting manual I ever owned.
I knew these answers would come.. Then you have never driven it at wide open throttle trying to hit third, these cars have a history of this, do a search it is a very COMMON issue.
Simple answer is yes it does.
Swapped out the stock shifter after 6 months in my 09 and the MGW is much more accurate, especially going into 3'rd. It will be a little more stiff, but it is much more accurate.
And I have had little to no rattle with my MGW. I run their race **** and I only get rattle, (more noise then vibration) at WOT.
Sorry if this offends anyone.....but it is 100% driver error if you don't follow the advice to use your palm for the 2-3 shift.
I've owned several C6 coupes and two C6 Z06's and have never missed a shift using this method. Even when speedshifting @7k rpm.
I believe Jamie Furman,and am positive that Ranger,are using the stock shifter. I'd wager if you took a poll of the fast lists,every driver on there(using a manual) uses the palm method.
Well yes, as a matter of fact I have driven at wide open throttle, sometimes being smooth on the handling and operation of the car yields the fastest time at the finish line.
But if you wouldve owned mustangs, you would know how primitive and old school they are... no safety crap, all power
that maybe a good thing or bad... depending on the driver.
The first thing I noticed was the "put in reverse" for my 05 M6. I was like WTF?!?!?
Second was the 1-4 skip shift.... I was like OMFG!!!
That was in within minutes of the first test drive LOL. Im paranoid when it comes to things like that
I find it bad enough when people use "OMG". However as a Christian I consider "OMFG" obscene to the extent as is unimaginable if it means what I assume it does. Therefor I would wish you reconsider before posting such an offensive acronym as that in the future.
The open palm method is the way to go. I had a chance to drive with Johnny O'Connell a few years back and he told me the surest way to miss the 2-3 shift is to try to fist the shifter. Use the meaty part of your palm and just let the springs do the work. Oh -- and yes, the MGW shifter helps, but will still get caught up if you try to fist it at WOT.
