Engine failures
Old Oct 22, 2011 | 10:47 AM
Heatman's Avatar
Heatman
Default Engine failures
I read alot about the Z06 engines taking a dump for various reasons even though some argue that it is a very few % over the amount that are out there.
Just wondering how the base model C6 engine has been holding up in comparison
Old Oct 22, 2011 | 10:49 AM
boraxman's Avatar
boraxman
Old Oct 22, 2011 | 10:50 AM
Vette_DD's Avatar
Vette_DD
No problems with the 4 I've had.
Old Oct 22, 2011 | 12:08 PM
CO Lightfoot's Avatar
CO Lightfoot
Based on forum threads, I'd say the C6 LS2/LS3 engines are holding up great.
Seems like threads about C6 base-engine failure have something to do with modifications-gone-wrong or a bad oil change (over- or under-filled, esp. dry-sump LS3) or other in-the-field screw-up.
If there was a factory problem causing LS2/LS3 engine failures, we'd be flooded with threads.
In fact, there are lots of threads about problem-free higher-mileage C6's.
CONSUMER REPORTS surveys confirm it: Less than 1% problem rate (their highest rating) for the C6 engine. I'm guessing that's skewed a bit by LS7 problems... so I'd conclude the LS2/LS3 is as close to perfect as it gets for a production engine.
Old Oct 22, 2011 | 12:45 PM
BayouCountry's Avatar
BayouCountry
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
I have a 2006 LS2 with 38,000 and no issues. Bought it used so who knows how the previous owner drove it. I have a nice 55mph junction on the way home where I can legally get on it so it's gotten near the red line a few times. Man, I hate it when someone is making the turn in front of me!
I just can't seem to get it under 22 mpg! The base model is perfect for the economy minded who have owned only fuel efficient cars most of their lives.
Old Oct 22, 2011 | 01:27 PM
Heatman's Avatar
Heatman
interesting. I'd love a c6z but it would be out of warranty so when I pull the trigger on the c6 it will probably be the base
Old Oct 22, 2011 | 01:44 PM
BayouCountry
See if you can purchase an extended warranty. If you are thinking Z06 then you probably won't be happy with just a base model.
Old Oct 23, 2011 | 04:44 PM
Heatman's Avatar
Heatman
would have a blower on either one so HP wouldn't be an issue. this would void any warranty most likely
Old Oct 23, 2011 | 05:01 PM
Bill Dearborn's Avatar
Bill Dearborn
How are you planning on driving the car? If you are like 90+% of Corvette drivers you won't drive it hard enough or long enough to have an engine failure. As far as I know all of the engine failures have occurred in cars that actually are driven and in addition see some very hard miles (such as track duty). A few quarter mile passes and putt putting around town won't put any body at risk of losing an engine unless they run it without any oil.
Bill
Old Oct 23, 2011 | 11:26 PM
RUBYREDVET's Avatar
RUBYREDVET
Bill
Very good point Bill. Also don't mod the LS7 motor. I believe some of the "reported" motors that blew up were modded.
Old Oct 24, 2011 | 08:22 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
No problems with my LS7. The vast majority of the Z06 motors have been fine. If you want to put anhialator cams, tunes and run 1/4 mile at a time I suppose you can count on some issues.
Old Jun 10, 2023 | 12:59 PM
panamamike's Avatar
panamamike
No plans on driving hard. Just don't want to inherit a money pit or something that can't be repaired.
Mike
Old Jun 10, 2023 | 08:56 PM
russ472's Avatar
russ472
Imo, any LS7, running factory heads is taking a chance no matter how hard you drive it.
Old Jun 11, 2023 | 09:46 AM
Dano523's Avatar
Dano523
LS7 has some heads that the valve seats where not symmetrical/on center with the guide channels, and would snap valves due to this. The other one is the motor rev's to 7K, so as the valve guide stems to guides wear too much (too much slop), could have the same problem with the valves snapping from not seating square as well.
So due to this, most will just have the factory valves swapped out SS vavles with new guides installed, as well as the valve seats recut as well.
This solves if the heads where not produced correctly to begin with, as well as the SS valve being stronger so they do not snap as you do get wear between them and the stems, with them not seating square every time.
Old Jun 11, 2023 | 07:28 PM
old motorhead's Avatar
old motorhead
12 year old thread. I've hot rodded all manner of LS engines over the years. Supercharged and n/a. Unless you're a mullet, they're pretty much bulletproof.
To Engine failures
