Window Indexing issue -
Old Oct 23, 2011 | 10:02 PM
3L337 C6's Avatar
3L337 C6
Default Window Indexing issue -
Took the battery cables off today to shave the crud build up and when I put it back on the car windows do the usual window rolling down slightly/indexing - but when I close the door again it does go back up into place. Anyone know a solution to this one? Help greatly appreciated. Thanks,
Old Oct 23, 2011 | 10:04 PM
ALD_Z06's Avatar
ALD_Z06
Put the windows down all the way and hold the switches down for 10 seconds.
Old Oct 23, 2011 | 10:06 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
Old Oct 23, 2011 | 10:12 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
WTF?
Old Oct 23, 2011 | 10:18 PM
ALD_Z06's Avatar
ALD_Z06
Originally Posted by KenHorse
WTF?
Did it today. I forgot what exactly to do but I remembered at least to hold it in one position either up or down. So, held the two switches down for 5-10 seconds and that did it.
Try it, you'll like it!
Old Oct 23, 2011 | 10:26 PM
KenHorse's Avatar
KenHorse
Only thing I've ever read in the Manual (or heard about) was this:
Window Indexing
This feature automatically lowers the window a
small amount when the door is opened. Then,
when the door is closed, the window will raise to
its full up position. If either window does not
index properly, it could be due to loss of power.
Before returning to your dealer for service, perform
the power window initialize procedure following.
Power Window Initialize
After a power reconnect such as battery
replacement, the window index-up feature will not
function until the system is initialized. Once
power is restored, do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds
and release.
Old Oct 23, 2011 | 10:30 PM
ALD_Z06's Avatar
ALD_Z06
I read that tonight as well but I guess as long as you hold it in either the up or down position, it will work.
I definitely held it down only as I forgot the correct way. I was shocked myself.
Old Oct 24, 2011 | 12:27 AM
3L337 C6's Avatar
3L337 C6
up for 3 sec solution worked - thank you for your help.
Old Oct 24, 2011 | 01:57 AM
KenHorse's Avatar
KenHorse
Old Oct 24, 2011 | 07:14 AM
GOLD72's Avatar
GOLD72
The Owner's Manual is your friend.
Old Oct 24, 2011 | 08:41 AM
RaleighTL's Avatar
RaleighTL
Not ignoring you question but if you are getting a lot of "crud" build up at you battery connection you most likely have a battery that is venting where the post is cast into the case. The world will not end if you put up with the situation, but check out the web and you will find that the manufacutre should be willing to replace it if it is still under warranty. I made the mistake of "putting up with it" on the wife's Lexus RX-350 but on the 3rd cleaning the battery connection, the cable clamp broke as it was nearly eaten 1/2 into (not the heavy duty lead connectors of the good old days). They replaced the battery and cable under warranty.
To Window Indexing issue -
