Please help me!!! white smoke and water!!
there is a monsoon in south florida right now and i hit an unexpected puddle ( "water" not the type of dog) and my car bogged and then shut off. i came too a complete stop then tryed too start the car and it did not work. i sat there for one min and then tryed again and it started but the idle felt a little rough. the whole way home i did no more the 15 miles/hour. at a couple red lights i saw white smoke and the same when i pulled in my driveway. i think water got sucked im my intake i have the killer bee 2 on an 08 LS3 car.
AM I TOTALY FU*KED???
Received 3,088 Likes
2021 C6 of the Year Finalist - Modified
As long as you didn't bend a connecting rod by hydrolocking it with the water, you will more than likely be ok.
ohh brother. what do you think would be the best course of action for tomorrow?
let the car sit and idle in the driveway?
go put some pure 93 octane in it? you know the one without any ethonol.
or warm it up and go cruse the highway?
6th Gear
Did the same thing several years ago on a Trans am, Mine locked up!! Pulled plugs and shot water clear across the garage. Drained oil, replaced plugs and drove it another 90,000.Think youl b OK as long as you didn't bend a rod. Scared the sheetz out of me though
Actually, the ethanol may help. Didn't you ever hear of adding alcohol to your tank in winter to react with moisture in the fuel and avoid icing. It has been many years since I worried about fuel icing, but I recall the alcohol trick for dealing with moisture in gas.
Ah, don't think totally --------------- I did the same thing many years ago. In my instance the vehicle would not even start. My air filter was soaked - new air filter and I was back up and running.
E
I had that problem with my old Tahoe. Turned out to be a blown head gasket. The white smoke was coolant. I would suggest you check your compression, and make sure no water got in your oil.
SoCal Events Coordinator
St. Jude Donor '12
I hope the best for you but as someone else pointed out, white smoke from the exhaust is a sign of a blown head gasket. good luck to you.
the hood open and remove and inspect the air filter. (wet)
The car ran home so it couldn't have hurt anything mechanical.
If it was my car...I would not drive it. I would get it Horse Power Sales in Pompano Beach and let the experts look at it. If you injested water into the engine and did damage...Your insurance covers the cost of replaceing the engine. Quite commen in South Florida. The staff at HPS has worked with the insurance companies in the past. Please don't drive your car until you have an expert look at it. Just my two cents....Mike
Wounded Warrior Escort '11
Pull the plugs and turn it over a few times. Put them back in and see if it'll run normally. Yes, you can expect some steam from it for a few minutes but past that, if your coolant starts going down or you can smell coolant out the exhaust, contact the insurance company. If you modded the intake, you'll have a problem.
Ugh! People love to scare people!
OP, pull the plugs, crank it a couple of times, take off the air cleaner, dry and clean it and then change the oil. No guaranties but most likely you'll be just fine. If it were me I'd put the OEM filter assembly back on.
For an easy check, start it up and run for a minute or two. Then pull the dipstick. If it's pinkish and frothy looking = head gasket. Also remove oil cap, turn it over and see if any water droplets on bottom inside of the oil fill cap.. If pinkish and frothy, = head gasket.
If so - do not run it anymore - have it towed/flatbed to the repair facility of your choice.
Chances are you'll get lucky.
CF Senior Member
It's obvious your engine ingested a significant amount of water. Personally, I wouldn't run the engine or try to 'burn' off the water with higher octane fuel or some additive. If not yourself I'd take the car to a shop and 'open' the engine as necessary to drain the water, dry it out, change oil, etc. You may be able to dodge the bullet but I wouldn't risk further damage by running it. You just don't know. Do what you can to rid the water first. Good luck.
Granted, a true (bottom-feeding) CAI will make your car more susceptible to ingesting water and hydrolock but FWIW it can happen with the stock intake as well. Even the owner's manual warns against plowing through deep standing water. Don't think you're immune from ingesting water just because you have a stock intake.
