I have a 2007 with 10K on it without headers. It has the orginal wires and runs really well. My question: How often should the wires be replaced? Are aftermarket wires better?
The wires are only about 3 inches long anyway..so they never really get flexed....they should easily go the 100,000 miles till the plugs need changing.
Replacing spark plugs every other year is not preventative maintenance, it's a waste.
Spark plugs will last to 75k easily. Your not preventing anything, other than the local auto parts store going out of business.
Not true.
Spark plugs will "last" to 75k+ in the sense that they can make power and continue to pass smog tests, but a change at even 50k on an LS can yield a noticeable improvement at idle and low RPM.
Okay, but the point is that every other year is overkill. Your traveling what, 15k maybe?
How long each wire will "last" is subjective to the brand, the usage and the car. The term "preventative" or "proactive" describes measures done *prior" to problems arising. You can wait until something fails but I'd rather not - personal choice.
Every other year I have my shop do a number of things as maintenance. I pay them once for this instead of taking the car in numerous times for numerous issues and paying numerous shop fees.
The wires get tested on a meter. There's always at least one or two of the wires no longer performing to optimum. Cheaper to just buy a new set. Likewise with the plugs.
You can argue how long a spark plug wire will last all you like. I know mine are functioning perfectly.
To the OP, as stated above the stock wires are as good as anything out there so I wouldn't worry about replacing them if they are not damaged. For those that desire to, IMHO you should do whatever you believe is the best care for your car and enjoy it.
From my experience the spark plugs and plug wires hold-up quite well. You can find better aftermarket plug wires but the OEM plug wires work well enough. As mentioned, if it ain't broke don't fix it. For a stock, street driven car and in the absence of any problem, I wouldn't even think about plugs or plug wires until well after 50,000 miles. I prefer the NGK TR55 spark plugs and IMO it helps to put 'cool socks' over the plugs/plug wires.
I installed these some years back on my '99 Z/28. It only was a couple years old, but I had heard that the factory did not use anti-sieze on the plug (which, obviously, screw into an aluminum head). I wanted to put in a new set and make sure I could get them out the next time- the F body 4th gen is very hard to change the passenger side plugs.
Sure enough, the originals were dry as could be and may well have been a problem down the line. Still have the car and have never had an ignition/spark plug related issue. Or any other issue that was serious, either!
These wires are still working great and test out fine. I noticed that they use the stock Delphi boots on both ends...
Originally Posted by Turbo6TA
I doubt you really need new spark plug wires, but, if you really think you need them .. get a set of Magnecor KV85 Competition ignition cables.
These are 8.5mm and the best set of cables available. No gimmicks associated with these!
They also provide full suppression of both EMI and RFI, so they will not interfere with the Corvette's electronics.
Call Megnecor for the correct plug wires. There phone number is on there website.
for years now plugs come coated or plated from the manufacturer and require no anti-seize and some even say dont use it.
Your Camaros plugs were coated. GM would be insane not to use coated plugs to prevent Al/Fe galling in all their new cars.
