Winter Prep Complete
Old Oct 31, 2011 | 04:02 PM
GSRANDY's Avatar
GSRANDY
Default Winter Prep Complete
Finished prepping my 2010 GS (2726 miles) for winter storage today.
Shot the attached photo just before I drove my GS back into the garage and installed the cover for the winter.
• Add Sta-Bil to Fuel Tank.
• Clean Entire Undercarriage and Suspension.
• Remove and Clean Inside Surfaces of Wheels.
• Grease Rear Suspension.
• Increase Tire Pressure to 40 PSI.
• Apply Silicone Grease to all Weather Stripping.
• Apply 303 Protectant to Tires, Dash and all Trim Pieces.
• Connect Battery Tender.
• Place Tires on Carpet Squares.
• Wash / Apply Zaino AIO and Z-5 Protectant to Painted Surfaces.
• Polish Exhaust Tips.
Regards,
GSRANDY
Old Oct 31, 2011 | 04:29 PM
KGVette's Avatar
KGVette
wow..I know it will be here sooner than later but your grass is still green and leaves haven't even changed color.
Old Oct 31, 2011 | 04:37 PM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
Just had to remind me it's almost over!
Thanks...
Old Oct 31, 2011 | 04:47 PM
weathermaker's Avatar
weathermaker
I think you could have gotten an other month out of it.
Old Oct 31, 2011 | 04:48 PM
breecher_7's Avatar
breecher_7
Mine wont go away till they salt the roads and at that, it just goes in the garage and sits till spring, no special treatment......
Old Oct 31, 2011 | 05:18 PM
rchbn's Avatar
rchbn
Mine won't go away, just cleaned the interior today, then off to pick up the girl friend for a nice drive when she's off work. 89 now and heading to 91 then down to a bone chilling 61.
Old Oct 31, 2011 | 05:49 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
I'll drive mine until the first snow.
Change oil
Change clutch fluid (Ranger method)
Wash
Tire pressure to 35psi
Add Stabil
Connect Ctek
Fill gas tank
Cover and let sit.
Old Oct 31, 2011 | 06:46 PM
Vivid1's Avatar
Vivid1
all I do is change the oil, pump up the tires, hook up tender and put the cover on. I probably wont even wash it.
Old Oct 31, 2011 | 07:17 PM
trivette's Avatar
trivette
Took a vacation day today and did the storage prep to my '84 and '05. At this time of the year it's dark early, cool in the morning, and except for the chance of a nice weekend not all that great a time to drive them. Made it through another season with no mechanical or other issues, so good time to park them.
Old Oct 31, 2011 | 08:25 PM
jversluis's Avatar
jversluis
Default storage
This baby is getting all the driving possible till to cold to wash. Then she gets the detail and flannel blankie. She will run an occasional romp on the dry winter roads to stay alive til spring!
Old Oct 31, 2011 | 08:33 PM
speedlink's Avatar
speedlink
If you look at the trees, you will see almost all of the leaves are gone.
Old Oct 31, 2011 | 08:43 PM
BSE1956's Avatar
BSE1956
THAT'S the way to store the car.
But (you just knew there would be a but).
The car would be even happier if you changed the oil and filter.
I know it's not necessary with the low mileage, but the acids and other nasties in the oil are not kind to engine parts.
Might be a little much, but you will start the spring with fresh oil too.
BTW, mine gets driven until the 1st snow when the roads around here get a full dose of salt.
Old Oct 31, 2011 | 08:58 PM
gerryt's Avatar
gerryt
Too much sun here to ever put her away for the winter.
Old Oct 31, 2011 | 11:32 PM
sublime1996525's Avatar
sublime1996525
You had me worried, I thought I was gonna be the only one who didn't do too much to get cars ready for winter.
Old Nov 1, 2011 | 06:52 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
What are you preventing by putting this seafoam stuff in your gas tank?
Old Nov 1, 2011 | 07:10 AM
Torchsport's Avatar
Torchsport
It gels up in the injectors, when it sits for months. Clogs them up. Costing money.
It's a known issue. Gas goes bad.
Sea-foam helps prevent this.
Old Nov 1, 2011 | 07:16 AM
~Stingray's Avatar
~Stingray
So once the winter ends, can you just start the car right up with this seam foam stuff in your tank and fuel lines? Drive to the nearest gas station, fill up and drive without any worries.
To Winter Prep Complete
Old Nov 1, 2011 | 07:25 AM
4SUMERZ's Avatar
4SUMERZ
My car seasonal license plate expired on Oct 31.
Washed, waxed, interior cleaning etc, and in the garage with the jammies on. The battery tender plus will go on in a few days.
Next time it will be started is on April 1, 2012.
Old Nov 1, 2011 | 07:26 AM
designerRob's Avatar
designerRob
Regards,
GSRANDY
Way to take care of your baby. Some might think it's a bit much but I don't. I would however try to get a few more drives out of it.
Question, how did you go about cleaning the undercarriage and suspension?
Old Nov 1, 2011 | 07:27 AM
The Corvette Kid's Avatar
The Corvette Kid
I just bought my first new Corvette, It's a 2011 Cyber Gray Grand Sport and I have a couple of questions for you C-6 experts. First of all I noticed you guys are pumping up your tires, what is the reason for this, also the car only has about 700 miles on it, do I really need to change the oil before I put it away. Is it safe to leave a charger on the battery all winter with the car cover on. Thanks, Bob
