recommendations for a small air compressor
Old Oct 31, 2011 | 11:05 PM
webdzynes's Avatar
webdzynes
Default recommendations for a small air compressor
small air compressor - I'd like to keep something reliable in the car or easily transported. Any recommendations?
Old Nov 1, 2011 | 12:21 AM
DigitalWidgets's Avatar
DigitalWidgets
Just started losing pressure in the left rear tire recently. Been stopping at the gas station every couple of days. I've been wondering the same thing.
Old Nov 1, 2011 | 12:22 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Tire Rack sells a compressor that can also inject a tire sealant that is not destructive to the TPMS.
The Continental ContiComfortKit is small enough to easily fit in one of the trunk cubby's and costs around $80.
Old Nov 1, 2011 | 12:28 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Bought this little "Slime" compressor at Loews for about $13.
Works great and is one of the smallest available
http://www.slime.com/shop/tire-top-off-40020/
Even a short video on the link above.
_______________________________________
EDIT ... DON'T buy this pump. I just read a bunch of reviews on it, and almost everyone that has had this pump said that after about 3rd or 4th time they used it, the pump started to make a loud squeeling sound and then would start smoking and freeze-up ... End of story.
Well, I have used mine twice without a problem. Now I am worried that the next time it may fail.
Old Nov 1, 2011 | 12:32 AM
keyplyr's Avatar
keyplyr
This is a terrific 12 volt compressor. Heavy duty, well built with very long air hose. Pumps the tire up very fast. Plugs into cig lighter. I got it at Griots Garage but you can get it cheaper on the bay.
Also in my emergency arsenal
bottle of slime tire sealant
a good plug kit
... and a few assorted tools: needle nose pliers, flashlight, flares, a rug, a bottle of soapy water & band aids.
Although I do carry a very good 12 volt compressor and a plug kit/tools as a last resort, I highly doubt I would ever crawl around on the ground to try and patch a tire on the road.
The pump will hopefully keep enough air in a tire w/ a slow leak to get to a service station. Anything short of that and I'm calling roadside service (AAA.)
I live in California with great roads and rarely am I very far from a service center. In 48 years of driving I've had exactly 1 flat tire and that was a slow leak, so this works for me.
Old Nov 1, 2011 | 12:49 AM
mikeCsix's Avatar
mikeCsix
I like compact pumps and tire repair kits, I also ride motorcycles - I have a honda ST1300abs and so needed something very compact and robust. I found this product:
http://www.pashnit.com/product/cyclepump.html
The adds will speak for themselves, I have used mine at the track when adjusting tire pressures. I have the dial tire gauge listed on the web page that is accurate and allows me to read the pressure while the pump is working.
What I also like is the pump is made in the US in MountLake Terrace, Washington - close to home. I easily carry a tire repair kit that fits inside the pump case along with a Leatherman multi-tool.
Old Nov 1, 2011 | 02:31 AM
2006c6keller's Avatar
2006c6keller
Default Another option?
The small one you list as defective here is $9.99 at Walmart.
Now the next question, I just bought the following at Walmart for $15.00 even. It is a Slime Tire Inflator "AUTO-MID-SIZE-SUV" with LED light, round guage, two switches, and claims to fill a STANDARD tire in approximately 8 minutes. I use it last night after my Coleman compressor went out with valve trouble. I topped off two tires with about 5 lbs additional in each. The pump worked very well in 50 degree weather. The catch per instructions, after 10 minutes let pump cool for 25 minutes, opps! I didn't have the temperature constraint because of the ambient temperature of 50 degrees.
I really don't know what to say now for $15, BUT it did pump VERY QUICKLY and the guage was accurate! I'm not hyping the pump, just stating facts.
Old Nov 1, 2011 | 03:20 PM
Vette5.5's Avatar
Vette5.5
As "keyplyr" mentioned, if you're going to bother with a compressor, get a good one, or could be there all day trying. The Griots unit's a Viair 70P and very good. I decided on the next size 90P, as clips directly to the battery, avoiding posible popped interior fuses. Comes in a nylon case, and easily fits into one of the rear storage cubby's.
Old Nov 1, 2011 | 03:31 PM
CMY SIX's Avatar
CMY SIX
150 psi Viair on Amazon for about $45.00 shipped comes out of Buena park or Anaheim Ca? the one with all the BS aint as good
Old Nov 1, 2011 | 04:03 PM
tloon's Avatar
tloon
I have that Viair and it is great.
Old Nov 1, 2011 | 04:13 PM
Thrash's Avatar
Thrash
Threaded CO2 cartriges ... REALLY SMALL
Old Nov 1, 2011 | 04:36 PM
360Rocket's Avatar
360Rocket
St. Jude Donor '12-'13-'14
This is a carryover from my Roush ownership days. The 360R carried a 20 inch spun aluminum spare wheel, the same used as a spare on Lambos. It was needed to clear the large Alcon brakes on those cars but had to be carried deflated to fit in the trunk spare tire well. So Roush included this pump/sealant kit. I've since let 2 Roushes go but have always kept this kit for the next car.
Old Nov 1, 2011 | 08:11 PM
phileaglesfan's Avatar
phileaglesfan
I've been topping off my tires with a free one I got from Michelin. About 1 PSI per 2 minutes. I think I'll get the Viair now.
Old Nov 1, 2011 | 08:13 PM
keyplyr's Avatar
keyplyr
Old Nov 1, 2011 | 08:35 PM
candlemuse's Avatar
candlemuse
I have been using Cyclone Portable Air Compressor Master Flow .
Very happy with it. It has always been reliable for me . I got it from Pepboys.
Old Nov 1, 2011 | 08:45 PM
Grzldvt1's Avatar
Grzldvt1
Had two flats in the field. Learned on the first one, you can never have enough light, so I picked up one of these - Campbell-Hausfield 12 Volt Inflator
Having that spotlight shining on the tire when you are trying to find the valve at night is a huge benefit.
Old Nov 1, 2011 | 08:52 PM
z28koda's Avatar
z28koda
I bought the slime air compressor with a flashlight and tire patch kit (Not slime) works great!
To recommendations for a small air compressor
Old Nov 1, 2011 | 09:00 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
I just bought this. Most of the reviews I found were very positive and it is very versatile and small.
Black & Decker ASI300 Air Station Inflator ....... for $41.30
http://www.amazon.com/gp/product/B00...00_i00_details
Old Nov 1, 2011 | 10:39 PM
Turbo6TA's Avatar
Turbo6TA
Originally Posted by Grzldvt1
... you can never have enough light, so I picked up one of these - Having that spotlight shining on the tire when you are trying to find the valve at night is a huge benefit.
Will that tire inflator fit ok in one of the cubbies?
I guess it plugs into the cigarette lighter?
Old Nov 1, 2011 | 11:49 PM
kedar's Avatar
kedar
St. Jude Donor '12
Viair 85p. Also have an adapter to connect male end of cigarette lighter to battery terminals.
