Any BBk's that fit behind base c6 wheels?
Im gonna be upgradeing my brakes as a winter project,and dont know if im gonna go widebooty and use wider wheels.If i decide not to is there stock or replica c6 wheels and what bbk could i use?I plan on.doing.some track events as well as autocross but mostly my car is a daily driver.
Mike
Mike
CF Senior Member
You're really limited with the stock wheels. I'm not aware of any true big brakes that'll fit. IMO at the least you'll need new wheels. You can get wheels that will accommodate big brakes and allow you to run Z06 size tires on a stock body C6, however, not all wheels that'll accommodate Z06 tires on a stock body C6 will work with big brakes. You're really limited for space in the rear. For the greatest versatility, I recommend you go to the Z06 rear quarter panels and buy 9.5" or 10" front wheels and 12" wide rear wheels. I like CCW wheels but whichever wheel you go-with confirm with the vendor or manufacturer in advance that the specific wheels you want will work with big brakes. Good luck!
Mike
Mike
