little filter
Old Nov 11, 2011 | 04:54 AM
secondvette's Avatar
secondvette
Default little filter
I had the vett on ramps and oil drained before i remembered i had not picked up a replacement oil filter....duhh,,S0 in the beater i go to our gm dealer to get a filter.I tried to find the part number in the manual but gave up looking --so just asked for a filter for a 6,2.The counter girl hands me this tiny filter.aI looked at it and said this can not be the correct filter for that large engine...but yepp,iti is,[I] alwaays thought that a large filter was better especially for a large engine.But once i saw the spot it fits in it made sense.Now time to store her..
Old Nov 11, 2011 | 05:33 AM
1 C6 2NV's Avatar
1 C6 2NV
Myth Buster
Delco PF46E
Old Nov 11, 2011 | 07:26 AM
GOLD72's Avatar
GOLD72
Originally Posted by 1 C6 2NV
Delco PF46E
He apparently has a 6.2L LS3 so it has to be a Delco 48 series or equivalent aftermarket filter number that uses the 48 series mounting thread pitch. 44 or 46 series will not fit a LS3/LS7/LS9 engine of any model year.
Old Nov 11, 2011 | 09:16 AM
Wayne O's Avatar
Wayne O
CF Senior Member
FWIW Autozone carries ACDelco filters....probably a bit cheaper than buying through the dealership. Happy hibernation!
Old Nov 11, 2011 | 06:49 PM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
We got three Chevys and all use those small filters: PF46E, PF47, UPF-48R
They all look just like the other (dimensionally anyway), why can't they make just one filter that works for all of them?
Old Nov 11, 2011 | 11:51 PM
JoesC5's Avatar
JoesC5
PF46 does not have a bypass valve(it is located in the engine above the oil filter) and the PF 48 has the bypass valve as the later engines do not have a bypass valve in the engine and the oil filter MUST have the bypass valve. Even though the two look the same, the threaded mounting hole has a different diameter and different thread pitch between the PF46 and the PF48 series filters, thus they are not interchangeable. I don't know what the PF47 is.
To little filter
