Breaking loose!
Old Nov 18, 2011 | 03:39 PM
05blkbeauty's Avatar
05blkbeauty
Default Breaking loose!
Been noticing since it has cooled off that my '05 C-6 6spd breaks loose easily in 2nd gear on a lot of road surfaces. I have the BFG g-force tires with good tread- is this normal for most 'Vettes or are my tires the culprit?
Old Nov 18, 2011 | 03:52 PM
DopeyDude's Avatar
DopeyDude
Mines been breaking loose very easily also since the weather has cooled down. Same as you with good tread but i have the Michelin Pilot Sports.
Old Nov 18, 2011 | 03:54 PM
jthurik's Avatar
jthurik
Yeah I get serious wheel spin at anything under 65mph in this weather....even with Nitto Nt05R's
Old Nov 18, 2011 | 04:14 PM
harlanmott3's Avatar
harlanmott3
I have the same issue, seems to me its a huge issue. I think its the tires, I hope someone can confirm for sure. I'm on the stock GY's ZP's.
Old Nov 18, 2011 | 04:32 PM
z28koda's Avatar
z28koda
Its just the cold weather fellas! Do a nice burnout when you leave the house to warm em up and you should be fine!
But really it is because the ground and tires are cold. If you're really that worried about it switch to an all weather or winter compound tire and you shouldn't have the issue any more.
Old Nov 18, 2011 | 05:23 PM
05blkbeauty
I guess having a car with this kind of power is nothing to get upset about. Sounds like a lot of other people have the same problem with different tires. This is controllable, and I don't mind going a little sideways in 1st gear (we all love that), but when youre going 45-50, it gets your attention! I have a lot of people ask why I would want a car like that, I guess they just don't understand! Love the Vette!!
Old Nov 18, 2011 | 05:28 PM
C6FirstVette's Avatar
C6FirstVette
It is called "summer ultra/etc performance tires"... do not begin to press them into service (like it is in the summer with 75 deg++ temps)...they get very non grip
Old Nov 18, 2011 | 05:40 PM
DopeyDude's Avatar
DopeyDude
I must say I do (secretly) have fun when they break loose.
Old Nov 18, 2011 | 05:43 PM
JoesC5's Avatar
JoesC5
It's a combination of your tires and the engine's computer. When the weather is hot, the computer will start pulling engine timing when the intake air temps goes above 89 degrees, seriously cutting horsepower. Combine that with some additional timing being pulled when the coolant temp starts moving up in hot weather. When you have cool air feeding the engine, no timing is being pulled, and the engine is making it's full rated horsepower, combined with tires that don't get good traction in the cold, and you have wheelspin.
Old Nov 18, 2011 | 05:44 PM
jthurik's Avatar
jthurik
there is a guy that was driving a 7 series BMW that looked like he found some serious pucker factor when I was sideways at 60......
Old Nov 18, 2011 | 06:11 PM
jthurik's Avatar
jthurik
that's what methanol is for!
Old Nov 18, 2011 | 06:22 PM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
Broke loose wenesday for sure! It was 14°F that morning.
Temp was all the way up to 41°F today!
Still broke loose!
Old Nov 19, 2011 | 04:09 PM
diamond78's Avatar
diamond78
Okay - so I have to ask - are you doing it on purpose?? So far in the week we've had ours...so I know it's not long...I have broken it loose in 4th on an on-ramp and hubby has done it a couple times in the lower gears. BUT I have driven it all around town in mid-cold conditions (30's one morning, 40's high) and never had a problem. So are you really getting on it to produce these results?
Old Nov 19, 2011 | 04:30 PM
sublime1996525's Avatar
sublime1996525
It's definitely the cool weather. Even my Cavalier breaks the tires easier.
Old Nov 19, 2011 | 05:41 PM
jackhall99's Avatar
jackhall99
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Summer performance tires will not hook up in cold weather! It can be scary and even downright dangerous to drive them in 40 degree or lower temps.
I mount A/S tires in Oct. and will keep them on until April or so.
Old Nov 23, 2011 | 12:04 AM
05blkbeauty
As far as how much power am I applying- obviously, I can drive easy enough that this is not an issue. I'm talking moderate to slightly heavy acceleration (not floored). It is a condition that started when the pavement cooled off. I was really more concerned about the BFG's maybe not being the best tires for traction, but it sounds like it's not just the BFG's from the responses I've seen so far.
Old Nov 23, 2011 | 12:09 AM
Rogers 07's Avatar
Rogers 07
Hadn't noticed, what is this break loose thing of which you speak
To Breaking loose!
Old Nov 23, 2011 | 11:06 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Cold weather and/or cold tires can be downright dangerous....drive accordingly.
Old Nov 23, 2011 | 11:11 AM
Corvettinator's Avatar
Corvettinator
Of course, this can be exhibition of speed, a misdemeanor in California.
Glad to see I'm not the only one having these issues, even in sunny CA. Thought it was just the crappy GY F1's.
Old Nov 23, 2011 | 11:12 AM
ArcticLS3's Avatar
ArcticLS3
If you want to run your Corvette in the cold temps you need to get tires built with a different compound that is able to handle the cold weather.
I park the Vette for the winter, but i have a set of snow tires for my other vehicle... i swear by them now.
