Using the GPS navigation system
Other car manufacturers do have this restriction.
I have not yet met a built-in nav that doesn't lock out destination entries while moving, although there are probably some that allow it.
The C6 nav will allow you to use the first page of Previous Destinations while moving, I've used other systems which don't even allow that.
2. What year is your Sonata? Our 2000 Odyssey would allow address entry while driving but later model years--after car manufacturers wised up--would not.
Black Friday sale at Best Buy and picked up a Garmin Nuvi 40LM for $85. Lifetime free map updates at 4/year. I have an older Garmin that needed a map update(four years since I last updated it) but it was $50 for a one timer and $90 for a life time map update. Saved $5 and bought a new 40LM with a larger screen, with more features. How can anyone justify $200 every year to buy new CD updates for their factory NAV? I wish now that I had saved the $1750 I paid for the factory NAV as I would have that money in my bank account plus I would have the 6 disc CD player instead of the single disc player standard with the factory NAV.
I only use the Garmin from now on and it can be programmed on the fly.
I have not yet found all the perks of the car. But it does have voice activation does it not? Seems like I should be able to enter a destination by voice.
I have not noticed this restriction on any Honda we have owned. I'm pretty sure we have had more than one occasion to add a destination while driving. We can also run everything from the radio to the air conditioning via voice commands. I haven't tried adding a destination via voice though. I wonder if it works on either car.
OnStar navigation, a totally separate and distinct feature, does allow you to speak your destination in detail.
Navigation related voice commands available on the Corvette Navigation unit as per nav manual which is quite extensive and includes the Destination Commands I have highlighted in red :
"Position Commands
Current Position, Current Location, Show
Current Position, Show Current Location:
These commands will cause the system to display
the vehicle’s current location on the map screen.
Map: This command will cause the system
to display the map screen.
Map Commands
Zoom In: This command will cause the system to
zoom in when on the map screen.
Zoom In Maximum: This command will cause
the system to zoom in to the minimum available
map scale when on the map screen.
Zoom Out: This command will cause the system
to zoom out when on the map screen.
Zoom Out Maximum: This command will cause
the system to zoom out to the maximum
available map scale when on the map screen.
Heading Up, Change to Heading Up: These
the Vehicle Up heading when on the map screen.
North Up, Change to North Up: These
commands will cause the system to display the
North Up heading when on the map screen.
Map Direction, Change Map Direction: These
commands will cause the system to change
the vehicle’s direction from North up to heading up
or heading up to North up on the map screen.
Mark, Mark This Point: These commands
will cause the system to mark the location as a
memory point while on the map screen.
Right Map Zoom In: This command will cause
the system to zoom in on the right map when
in dual map mode.
Right Map Zoom In (Maximum/Minimum
Scale): This command will cause the system to
zoom in to the minimum available map scale
on the right map when in dual map mode.
Right Map Zoom Out: This command will cause
the system to zoom out on the right map when
in dual map mode.
Right Map Zoom Out (Maximum/Maximum
zoom out to the maximum available map scale on
Right Map [Change to] / [Show] North Up
[Mode]: These commands will cause the system to
display the North Up heading on the right map
Right Map [Change to] / [Show] Heading Up
to display the Vehicle Up heading on the right
map when on the map screen and in dual
map mode.
Right Map [Change Map] Direction: This
command will cause the system to change from
North Up to Heading Up or from Heading Up
to North Up.
[Show/Change to] Dual Map Mode: This
command will cause the system to change the
map display to dual map mode.
[Show/Change to] Single Map Mode: This
map display to single map mode.
[Change to] 3D Map [Mode]: This command will
cause the system to change the map display to
the 3-dimensional map.
[Change to] 2D Map [Mode]: This command will
the 2-dimensional map.
Home, Go Home: These commands will cause
the system to enter the Home destination as
a waypoint or final destination, if a home
destination has been stored.
Go to Starting Point, Previous Starting Point:
enter the last available starting point as a waypoint
or final destination.
[Go to] Previous Destination: This command
will cause the system to enter the last available
destination as a waypoint or final destination, if
one is available.
[Go to] Preset Destination [Number] (number):
This command will cause the system to go to
the preset destination number. This preset
destination can be chosen as a waypoint or a
destination. There must be a location stored in
the preset destination number that is chosen. For
example, first store a location in Preset
Destination 3. Say “Go to Preset Destination 3.”
The system will go to Preset Destination 3
and prompt you to choose it as a waypoint or
destination.
Add [to] Waypoint: This command will cause the
system to add the current marked point as a
waypoint. This command is used after the following
commands have been used: Home, Go to
Starting Point, Go to Previous Destination.
Enter Destination: This command will cause the
system to add the current marked point as the
final destination. This command is used after the
following commands have been used: Home,
Go to Starting Point, Go to Previous Destination.
Guidance Commands
Repeat Guidance, Repeat Voice: These
commands will cause the system to repeat the last
available voice prompt guidance command if a
destination has been set.Louder: This command will cause the system to
increase the volume of the navigation voice
prompts.
Softer: This command will cause the system to
decrease the volume of the navigation voice
prompts.
Voice Guidance Off: This command will cause
the system to turn off the navigation voice prompts
if a destination has been set.
Voice Guidance On: This command will cause
the system to turn on the navigation voice prompts.
[Change to] Arrow (Guide/Guidance): These
to Arrow Guidance screen view in the Guidance
Menu if a destination has been set.
[Change to] Turn List (Guide/Guidance): These
commands will cause the system to change to
Turn List Guidance screen view in the Guidance
[Change to] Freeway (Guide/Guidance): These
Freeway Guidance screen view in the Guidance
Menu if a destination has been set. This command
is only available if you are on a freeway.
[Change to] Intersection (Guide/Guidance):
These commands will cause the system to change
to Intersection Guidance screen view in the
Guidance Menu if a destination has been set. This
command is only available when the next turn is
less than 0.5 mile (800 m) away for city streets and
2 miles (2 km) away for freeways.
Entire Route, Entire Rout Map, Route Overview:
display the entire route if a destination has
been set.
Reroute: This command will cause the system to
generate an alternate route to a set destination
while on a planned route.
Detour, Detour Entire Route: These commands
will cause the system to activate the detour
feature when driving a planned route.
Next Waypoint Map: This command will cause
the system to display the map view of the
next waypoint location if one has been set.
(First/Second/Third/Fourth/Fifth) Waypoint
to display the map view of the named waypoint
location if it has been set.
Destination Map: This command will cause the
system to display the map view of the final
destination location if one has been set.
Yes: This command will confirm system talkback.
No: This command will cancel a command.
(Delete/Cancel) Destination: This command will
cause the system to cancel the current
destination.
(Delete/Cancel) All Waypoints and Destination:
This command will cause the system to cancel
all currently set waypoints and the final destination.
Quick: This command will cause the system to
select the Quick route when a destination has
been set.
Normal: This command will cause the system to
select the Normal route when a destination
has been set.
Short: This command will cause the system to
select the Short route when a destination has
been set.
Point of Interest (POI) Commands
The following commands will cause the system to
display icons if they are available on the map
screen when the map scale is set to 1⁄2 mile (1 km)
or less.
Automobile Commands
• Auto Service And Maintenance, Auto Service,
Maintenance
• Automobile Club, Triple A
• Car Park
• Car Wash
• Gas Station, Gas
• Other Automotive
• Parking
• Parking Garage
• Parking Lot
• Rental Car Agency
Entertainment Locations
• Amusement Park
• Botanical garden
• Campground
• Casino
• Cinema
• Golf Course
• Horse Racing
• Marina
• Museum
• National and State Parks
• Park & Recreation, Parks & Recreation
• Performing Arts
• Ski Resort, Skiing
• Speedway
• Sport Complex, Stadium
• Tourist Attraction
• Video Rental
• Winery
• Zoological garden
Financial and Government Offices
• ATM
• Bank
• Business Facility
• City Hall
• Civic Center, Community Center
• Convention Center, Exhibition Center
• Court House
• Government Offices
• Higher Education, University, College
• Hospital
• Library
• Other Financial Services
• Police Station
• Post Office
• School
• City Center
Personal Services
• Beauty and Barber Shops
• Dry Cleaning
• Health and Fitness Club
Restaurant Locations
• American Restaurant, American Food
• Chinese Restaurant, Chinese Food
• Coffee House
• Continental Restaurant, Continental Food
• French Restaurant, French Food
• Ice Cream Parlor
• Italian Restaurant, Italian Food
• Japanese Restaurant, Japanese Food
• Mexican Restaurant, Mexican Food
• Other Restaurant, Other Food
• Restaurant, I’m Hungry
• Seafood Restaurant, Seafood
• Show Restaurant
• Thai Restaurant, Thai Food
Shopping Locations
• Convenience Store
• Department Store
• Grocery Store
• Home and Garden
• Other Retail Store
• Pharmacy
• Shopping, Shopping Mall
• Specialty Food Store
Transportation
• Airport
• Bus Station
• Ferry Terminal
• Historical Monument
• Hotel
• Park & Ride
• Rest Area, Rest Stop
• Tourist Information
• Train Station
POI Off: This command will cause the system to
turn off POIs so they do not appear on the map
screen.
Today I read through here and didn't see a single mention of this unit by Sunset Orange Creations: http://shop.sunsetorangecreations.co...2?keywords=nav
BJK
I assume there is some sort of satellite based updates like with my DirectTV unit.
With OnStar capability, there should be no reason for DVD updates. Updates could be downloaded (automatically) to GM cars with OnStar (enabled or disabled).
My 2012 Range Rover allows me to put in addresses, search, etc while moving...but the best thing is the voice prompts. It also is upgraded at the dealer by firmware, since it has a 500GB NAV Hardrive.
That being said, I have had NAV on every GM truck I've owned, and while it has its quirks it never has failed at getting me to a destination.
Aftermarket looks just that-aftermarket...and no way am I putting a 100.00 NAV stuck on my windshield in a 60K+ vehicle. Tacky.
The Vette is no different then the GM trucks I had- but where it sucks is having to buy update discs. That is pure BS IMO.
Most of the time it tells me 'I'm there' when I actually have another 50 to 500 yards to go.
Anyone else have a similar problem with the factory NAV?
