Bluetooth help
Old Dec 1, 2011 | 08:23 PM
hondaamer's Avatar
hondaamer
Default Bluetooth help
Just got an I4s and paired it with my '10 Coupe. Everythings ok until I try to use my contact list through Bluetooth. It seems like Siri hangs up on me. If i disconnect Siri everything is fine. Any Apple/bluetooth experts out there to help me? Thanks
Old Dec 2, 2011 | 09:10 AM
Sickem Dawgs's Avatar
Sickem Dawgs
I'm not sure but you seem to have competing services which could be causing the hang up because the command is not recognized. Your using bluetooth through the car to access the phone...siri is a separate app which the bluetooth doesn't activate. We do think it can be done..of course I think bluetooth should also connect to the nav system so I can update directions that way!
I'm sitting here with my tech nerds trying to figure out this and how to get it to work...i have the vette but none of us have the i4s!
I had to pair the phone and then program certain folks names (users manual has good directions) and numbers the first time into the system and then the call goes through fine that way..not what you're looking for but in the mean time it will work.
Old Dec 2, 2011 | 09:16 AM
topper7788's Avatar
topper7788
Unfortunately my corvette is a non Bluetooth car so I can't help as far as the Corvette. I can say I use Siri through the bluetooth on my Honda with no issues all the time... Actually works great...
Old Dec 2, 2011 | 10:22 AM
Sickem Dawgs
How did you set it up to work? This may help..
Old Dec 2, 2011 | 10:41 AM
topper7788's Avatar
topper7788
Siri will not activate unless you push and hold the home button... but once you do that my bluetooth picks up the activation and it takes requests through the cars bluetooth system... great for dialing numbers etc.. especially for me as i never remember anyone's phone number...
To Bluetooth help
