Small Problem???
Old Dec 14, 2011 | 06:55 AM
VET4LES's Avatar
VET4LES
Originally Posted by AtHomeSoda
I would have just put a floor jack in the rear, and pulled it out of the garage, far enough so I could jack up the passenger side front, and put the battery charger on the starter... then opened the doors, opened the engine compartment... and replaced the battery... AAA would not be my call... Then get a key made....
Old Dec 14, 2011 | 07:43 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
replace battery in your FOB
Old Dec 14, 2011 | 07:52 AM
RobLo's Avatar
RobLo
Read the posts about key in the car, making spare keys for your wallet, doesn't anyone (at least the early C6 owners) keep the key attached to the FOB, there's a loop on the FOB for a key ring and key....
Old Dec 14, 2011 | 07:55 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
And be sure to change your oil.
Old Dec 14, 2011 | 09:31 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I'm glad you resolved the problem. I suggest you carry the key with the fob and have a spare key for emergencies.
Perhaps not but if you have AAA (which I do) it's a viable option.
Old Dec 14, 2011 | 10:50 AM
bruno06's Avatar
bruno06
Had the dealer make me a key based on my vin #. Will try it and see if it works when I get home.
Old Dec 15, 2011 | 03:55 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
bruno06,
I've never personally heard of anyone having issues with a key they have cut from the VIN. Let me know if you have any problems.
Chevrolet Customer Service,
Justin
Old Dec 15, 2011 | 05:44 PM
bruno06's Avatar
bruno06
Dealer cut key worked perfectly. Got in the car without issue. Battery is dead, dead. I have to jack it up and move it a little so I can get the battery charger on it. It is parked right up against a cabinet that has the charger in it.... go figure.
I am close now. Get that battery charged, tested and then go riding. Have to wait til the weekend now. Busy, busy.
Old Dec 15, 2011 | 06:04 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If it is dead dead, you might have warped a plate and a charge won't help you at all. You may need to bite the bullet and replace the battery.
Elmer
