Stereo Volume
Old Dec 15, 2011 | 12:22 PM
Gilla81's Avatar
Gilla81
Default Stereo Volume
Does the stereo have a built in type of a governor on the volume controls? I've noticed when listening to the stereo, when I turn the volume up, it seems to hit a point where it just doesn't get any louder. I could turn the volume **** 20 times to the right and it just doesn't get any louder. I was guessing it might have been some kind of feature to prevent blowing speakers. Is their such a thing, or does anyone else have this same effect where the volume seems to top out and no matter how much you turn the ****, it just doesn't get any louder?
Don't get me wrong, my stereo works. I can adjust the volume to just a whisper, or I can crank it up. I say crank it up loosely. I would have thought their would be a nicer sound system in a car that costs so much and with bose speakers. It's descent, but not as loud as I'd like. It gets the job done though, and that's fine.
Old Dec 15, 2011 | 01:22 PM
Who Needs Turbo's Avatar
Who Needs Turbo
You think that because Bose is good at marketing.
You hear what you hear because Bose actually isn't very good at audio
I think you're just experiencing how weak the amplifier is. If you head down to the Audio & Electronics section of the forum you'll find many discussions about improvement options.
Old Dec 15, 2011 | 01:39 PM
cclive's Avatar
cclive
The volume **** is just an encoder wheel that sends its' signal to the cpu in the radio. So it really isn't a volume control as in the old days. The cpu gets the signal to turn up the volume but it will only turn it up so high.
Old Dec 15, 2011 | 01:44 PM
DSOMC6's Avatar
DSOMC6
It also makes a dfference as to what you are playing. Ie: Radio vs Cd vs downloaded MP3 files. I noticed mp3's I have burned onto a disc will not play as loud.
Old Dec 15, 2011 | 01:50 PM
1320fan's Avatar
1320fan
My question is how do you tell what level the volume is on? I'm not aware of any volume indicator that tells you?
Old Dec 15, 2011 | 01:54 PM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
I recently replaced my 6-disc Bose changer with the factory Nav system. There is a significant difference in the volume, the max volume on the 6-disc changer was higher than the max volume on the Nav.
Old Dec 15, 2011 | 02:02 PM
cclive's Avatar
cclive
You are right, there is none...only by listening.
Old Dec 15, 2011 | 02:19 PM
Gilla81's Avatar
Gilla81
I have the factory navigation system too. I'm glad it's not only me.
Old Dec 15, 2011 | 02:57 PM
petermj's Avatar
petermj
that would depend on the signal voltage coming out of each of these units, my guess is the nav has a lower signal output voltage since the amp is the same in both...
Old Dec 15, 2011 | 09:04 PM
C7Joy's Avatar
C7Joy
I have noticed that too. Factory made CDs seem to play the loudest in my car. The radio seems the weakest which may be related to signal strength.
Old Dec 15, 2011 | 09:58 PM
EVRose's Avatar
EVRose
Replace the speakers, add a sub and bypass the Bose amp with a good aftermarket one and the factory Nav kicks azz.
Old Dec 15, 2011 | 11:39 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
There is a volume level indicator on the Bose 6-disc changer/radio.
There is also an Auto Volume (and Auto EQ) feature but it sounds like your system is just running out of gas.
Old Dec 16, 2011 | 12:05 PM
1320fan's Avatar
1320fan
I don't have the 6 disc changer so I guess that's why I don't have a volume level indicator.
Old Dec 16, 2011 | 05:53 PM
Thrash's Avatar
Thrash
Put in new amps and the scenario changes completely. Bose sucks and must have cousins working at GM ...
Old Dec 16, 2011 | 11:18 PM
Mike02z's Avatar
Mike02z
I never seem to have any issue getting enough volume from my 08. Wonder why?
Old Dec 17, 2011 | 05:52 AM
Don-Vette's Avatar
Don-Vette
Umm..you know that black bar you see get bigger on the radio when you turn up the volume?
Old Dec 17, 2011 | 05:59 AM
1320fan's Avatar
1320fan
Umm no I don't because if you read my previous post I don't have the 6disc changer so as someone else posted in this thread there is no volume indicator unless you have that. Reading is your friend.
Old Dec 17, 2011 | 06:05 AM
Don-Vette's Avatar
Don-Vette
I only have the single disc player in my car and it shows it.
To Stereo Volume
