Lockpick 360
I have decided to get the LOCKPICK 360 with rearview camera. The installation looks to be straight forward but I don’t care to take on this task. I went to several audio installer shops in the Katy, TX area and most of them have not even heard of the LOCKPICK and the others have not installed one. I don’t want them to learn on my car. Can someone recommend an installer in the Houston area.
PS no pictures of the damage, I want no reminders of it
http://www.coastaletech.com/media/Co...od%20model.pdf
The question is if you only want the back up camera it would seem that there are other options available. There are way too many bells and whistles if all you want is the camera. Who needs a remote control. When you put it in reverse you should see the camera on the screen period. That's the way my MB works. IMO I think you should keep looking.
You are correct, all I really want is the camera. I current have the PAL unit for my ipod. I have search and I cant find want I want.
Open to any suggestions.
It wasn't difficult, just time consuming.
A good car audio shop shouldn't have a problem with it. There's no splicing of wires, just fuse taps. Granted, one of the steps is partially disassembling the head unit and running a new ribbon cable inside.
To clear up one misconception, you don't need to use the remote to see the rear view image when backing up: you just shift into reverse, and the camera image displays. The remote is used to activate the nav input override so you can enter addresses while in motion.
If I had it to do over again, I would have bought an all new head unit from the guy with Double D mods. He puts together packages for forum members and everybody has seemed very happy with him. I like the lock pick; it's ok, but the customer service at Coastal E Tech is a nightmare.
PS: I installed the lock pick for the primary purpose of a rearview camera. I didn't care about watching movies, etc, but it works for that.
