Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tires and Wheels
- How to Align Your Tires
Step by step instructions for do-it-yourselfers
Alignment Q. Before or after tire install
I could no longer resist.. I just ordered the PS2's and some repro. wheels on tire rack .. woo hoo... Man this corvette sure does eat up all my extra money
When I purchased my '06 AW coupe (58,000 miles), the front tires were worn on the inside. I called the dealer and he stated that GM sets up the alignment with negative camber for performance handling from the factory. I had the dealer do the alignment, and he said he would set the camber to 0 degrees for me, at my request, for better tread wear across the tire and the handling would be fine (I don't track it or drive it to it's limits). I'm happy so far. He also stated that the alignment would be good until I can replace the front tires.
MT
MT
MT
MT
I have to respectfully disagee. Camber will not change as you said, however, caster will not change either. Caster is the angle that the steering knuckle rotates on compared to a vertical line. Only way that would change is if you changed the rake of the car with different diameter changes front and rear. If both front and rear tires increased in diameter by the same percentage caster would not change. Toe if measured in degrees would not change either, it would only change if measured in inches depending upon where the measurement was taken.
You are correct that if toe is measured as an angle then it would not change but the specified angle should be related to the tire diameter since the toe in inches is what you are really trying to control. Again, using an extreme example of a 2 foot vs. a 6 foot tire and you should see that the needed angle to get a desired force would be much less with the 6 foot tire.
In any case, I hope we agree that when you start changing tire sizes you MAY need an alignment which contradicts those who say you never need an alignment after changing tires.
No problem, I agree. I was actually a little off in my original post. If one was to add one inch to each tire, the rake and therefore the caster would not change. However, since the front and rear tires must vary in diameter by a certain percentage then adding the same percentage of diameter to the front and rear would change the rake ever so slightly since you are adding the tiniest bit more diameter to the rear tire and therefore change the caster. That being said though, it should never be an issue since diameters must be kept close to stock to not upset the TC/AH.
