So I broke my radiator support...
#61
It's a bugger....
I did mine myself and did NOT remove front bumper cover. The hardest part was trying to hacksaw the frame (in place in a hard to get at position) as the wiring actually ran through it and there was no way to get it out without either cutting the wiring or cutting the frame.
#62
Those pics are great but did it the hard way. 2 hrs start to finish and you don't need to take of the fascia. Take off wheels, remove fender inner liner. Remove the old; all connectors can be disconnected. Take it to the bench and transfer any pieces to the new one. Again 2 hrs taking my time. I would also make sure you just buy the frame with the nuts installed with the purchase. I have seen it sold both ways.
#64
Finally done
Mine is just cracked half way through and bent at the center rivnut that holds the air dam. I was able to clamp it between two pieces of steel and straighten it. Then I mounted a 12" piece of 1" angle iron at the crack, along that 1" square tube that the air dam mounts to. Now I can't get the new air dam in. My old body is so sore and I don't know what I'm going to do next. Keep trying, I guess.
#65
I have broken my support at least 6 times to date.... track car... off track driving... I drill the rivnut mount and use 10MM bolt and compression nut on the back side.. faster and easier than installing rivnuts... Just me $0.02 ..... a
has anyone done a real weld to the joints.. they are sloppy from the dealer and crack when u fart in their general direction..lol
rsmith4604 (03-29-2017)
