Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Why is My Corvette Stuck in Park?
Guide to diagnose trouble with recommended solutions.
Stuck in park, 2005 C6
#61
g plant city fl
Having trouble with shifter getting stuck in park. Dealership replaced the shifter, still the same problem. Then they replaced brake sensor still not working. Noticed that service traction control system keep coming on. Wonder if this has something to do with it.
#62
I've been having the same problem!
So what is the answer? Do I take it to a dealer and have the shifter replaced? I hate to do that since it may be very expensive. sometimes I'll play with the traction control button. Or the emergency brake. It's making me crazy. What do you suggest?
The threads on this problem all seem to be years old. I'm looking for any new info on how to resolve this. Old posts seemed to fall into two fixes, expensive replace of shifter or fiddle with it till it starts working. The two times it has happened to me the fiddle with it has worked but I sure don't want to get stuck somewhere if the next time that does not work. I would like to be armed with the latest info if I have to go into a dealer. Thanks
#63
The permanent and cheap fix is to disable the parking lock pawl that is solenoid operated. The solenoid cannot be replaced separately. Plenty of threads show how to go underneath the shifter leather boot to access the pawl and either break it off or drill a hole in it and wire it permanently backwards. Once it is disabled, there is nothing to keep the shifter lever stuck in Park. I and others have been commenting on recent threads about this. Short of this, you might try pushing forward on the shifter lever after starting the engine and while still on the brake pedal, then moving the shifter out of Park. Worked everytime on my 07 A6 and my son's 08 A6 as both of our vettes were having periodic problems with getting the shifter to release out of Park.
#65
Hi Chris, Through Trial and Error it seems I have found a Way to Bypass the Sticking Shifter Issue, Try This Process and Follow The Exact Steps Outlined, 1. Press Ignition accessory Switch without pressing Brake Pedal . 2. You should hear a Click coming from The Shifter which is the Release of the Interlock Solenoid, 3. Apply Foot to Brake Pedal and Proceed to Start Ignition, 4. Shifter will now shift into drive freely, I Have now Incorporated this Process into every Start up for the Past 6 Months with no Issues , Hopefully it will Provide you with the Same Results, Good Luck, Joe.
#67
Park/Lock Feature on Automatic Transmissions is part of a safety issue mandated on all cars. Defeating the lock is not the best choice. Unfortunately GM has a significant issue with these going bad and the part is not replaceable. Its a solenoid that is manufactured into the complete shifter assembly. If you pull hard or force movement you can also break the shifter cable and forced to replace that also. The cost is often 700 - 1000 and appears to be the same exact part. (the entire shifter assembly)
Please take a moment to file a complaint with the NHTSHA on this issue. GM knows about the issue and has failed to make the necessary repairs and recall. Don't get stuck in a bad area, or forced to the expense of repair and towing. You can even get locked in the car as it believes its still in gear.
www.safercar.gov -- record every instance, even warranty and extended warranty replacement and repair.
Your comment about getting locked in the car can be solved by using the emergency door lever located next to the seat to open the door.
#68
Former Vendor
I spent around 900.00 for new cable, shifter, and labor. GM told me its not a big concern, and that they were not considering update to parts. So you get the same parts that initially failed ... mine was garage kept and less than 12k miles at time of failure.
I wish you all luck and success. Unfortunately having to modify and essentially rig a part to work properly was not in my best interest.
I still highly suggest reporting it ...
#71
This is a quick fix to get you going, most floor mounted automatics have a switch below the boot. Try lifting up the boot and look for the switch. Once you press it you should be able to shift out of park.
If you are not clear, just call any chevy service dept and ask about this switch. I have not checked but it might be in the manual.
Again, not sure if the Vette has one, but all others I have owned did.
Once you are on the move, you can drive it in for repair.
#73
Received 1,136 Likes
There is a thread here somewhere, with pictures I think, (or maybe just a post within a thread) saying that if you press in the right spot on the boot you can move the pawl. AFAIK, nobody has actually tried this to see if it's possible.
If I ever get stuck because of the solenoid/pawl problem I will slice the boot open. Buying a new boot would be the least of my worries.
But of course the SMART thing would be to take it apart now and tie the pawl back. I keep putting it off . . .
#75
My understanding of the emergency door release is that it is only cable operated. There is nothing electrical about it, which is the point of having this option when there is no power either because of an electrical failure/malfunction or being involved in a collision.
#77
Had my 05 in at the dealer for some work and this is what the service advisor told me: There is a switch on the brake pedal that activates the park solenoid that could be bad or not adjusted properly. You can tell if that’s the problem by the pushing accessory button and if you don’t hear the solenoid click by the shifter then that’s the problem. I haven’t heard about this on the forum.
#78
#79
Working for me,,,
Thank you for this tip, as I was having the stuck in Park issue nearly every drive. Now, since following the above steps, I haven't had any issue with the stuck in Park evil issue at all.
#80
Cruising
I'm cross posting this across the dozen or so threads I have found about this problem with the '05 C6 A4 being stuck in park.
That little microswitch is the culprit. It should go from open-circuit to short when activated. Mine is all over the place. It either needs to be replaced or cleaned.
