Wheels... Bolt patterns, offsets?
Old Jan 17, 2012 | 10:23 PM
tsoob's Avatar
tsoob
Cruising
Default Wheels... Bolt patterns, offsets?
Hi guys,
Tried searching but I can't find it.
Which bolt pattern (5x120...?) and offset do C6's use?
Old Jan 17, 2012 | 10:29 PM
1hotc6's Avatar
1hotc6
bolt pattern is correct and factory offsets are +57 mm in front and +79 mm in back, however many aftermarket wheel companies will suggest a slightly different offset
Old Jan 18, 2012 | 07:48 AM
R50THC5's Avatar
R50THC5
I hate using this word but, Can I assume that rims from my previously owned 2006 will fit om my 2009. I m thinking of powder coating them if so.
Old Jan 18, 2012 | 09:36 AM
haljensen's Avatar
haljensen
As long as you are going from C6 to C6, yes the wheels will fit.
If you are going from a C6 to GS or Z06 (or vice versa), no they won't.
Old Jan 18, 2012 | 06:27 PM
tsoob's Avatar
tsoob
Cruising
Ah cool. I was worried they might be 5x120.65 rather than 5x120.
cheers
To Wheels... Bolt patterns, offsets?
