Rotor Rust
Old Jan 21, 2012 | 07:45 PM
10GrandSport's Avatar
10GrandSport
Default Rotor Rust
I have a 2010 GS and just can't stand to see the rusted rotors through the wheels anymore. Does anyone know of a brand that won't rust in the center?
In addition, I would like to get the brake calipers painted when these are off (just don't like the silver look) any idea how much this will cost?
Thanks,
Scott
Old Jan 21, 2012 | 07:51 PM
Mad*Max's Avatar
Mad*Max
just drive the car
Old Jan 21, 2012 | 07:53 PM
saplumr's Avatar
saplumr
Originally Posted by Mad*Max
just drive the car
Yup...swept area = self cleaning!
Old Jan 21, 2012 | 07:54 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Send your calipers to Forum Vendor, Mike the Powdercoater. Search this for nothing but positive reviews.
You have 3 basic options for the rotors. From cheapest to most expensive:
Paint with high-temp paint, have them zinc plated or buy aftermarket rotors (slotted or cross-drilled, or both) that are already plated/etc.
Old Jan 21, 2012 | 08:43 PM
Don-Vette's Avatar
Don-Vette
I have never seen any rust on my rotors.
Old Jan 21, 2012 | 09:54 PM
VET4LES's Avatar
VET4LES
I painted mine with hight temp engine enamel.
From this:
To:
Old Jan 21, 2012 | 10:00 PM
C7Joy's Avatar
C7Joy
You mean like this....
Always get a little thin rust film right after a wash job, like this one. Short ride rubs them clean. Prolly shudda taken her for a spin before shooting this pic!!
Old Jan 21, 2012 | 10:10 PM
saplumr's Avatar
saplumr
I gotta ask Les...is that difficult to drive?
Old Jan 21, 2012 | 10:30 PM
10GrandSport
Sorry - I was not clear. The rust is located where the rotor meets the bolts of the wheel, not where the caliper meets the rotor. This is purely cosmetic, but takes away from the car...
Old Jan 22, 2012 | 09:39 AM
Mad*Max's Avatar
Mad*Max
okay - I just went and checked my car but I don't see rust in the centre and I have stock rotors (non-Z51 07)
Old Jan 22, 2012 | 10:27 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Drape a towel over all the exposed parts and spray paint it. Thats what I did when I painted my calipers. It's been 4 yrs now and the rust hasn't returned.
Old Jan 22, 2012 | 11:49 AM
C6FirstVette's Avatar
C6FirstVette
This thread might interest you>>>
http://forums.corvetteforum.com/c6-c...on-rotors.html
Zinc plating coats all surfaces in particular the cooling veins where rust can start...yes the brake-pad-to-rotor-surface area are 'self clearing' but a lot of rust comes from the hubs and cooling veins.
Old Jan 22, 2012 | 03:12 PM
scootertrash19's Avatar
scootertrash19
From this:
To:
That is some great paint, turned your solid rotors into cross-drilled rotors???
Old Jan 22, 2012 | 06:09 PM
speedraider's Avatar
speedraider
I was thinking the same,more like the BS theory
Old Jan 22, 2012 | 08:10 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Take your wheel off, use newspaper and mask off the suspension parts. Lightly sand the center and the outer rim. Then just use a high temp paint of your choice, I used VHT flat black, and spray the center, the rim, and inside the vanes. Don't worry about getting any on the rotor face, your pads will take it of after a couple of stops.
Old Jan 22, 2012 | 08:19 PM
Red89gt's Avatar
Red89gt
Calipers to mike the powder coater.
Search him and you will find plenty of happy vette owners.
I don't like the silver calipers either and would like to change mine to z06 red.
Old Jan 22, 2012 | 09:35 PM
Ed32's Avatar
Ed32
Very minimun rust in mine if any. Don't get them wet if it bothers you so much I always go back and forth in the driveway right after I wash the car, sometimes I drive it around the block to get them dry. I don't see how coating will really last since the rotors r exposed to such a high temps. That's just my 2 cents .
To Rotor Rust
Old Jan 23, 2012 | 01:12 AM
TommyV's Avatar
TommyV
Unless you track your car, the high temp coating will last. Mines been on for two years and looks new.
Old May 21, 2012 | 12:22 PM
RAM AIR III's Avatar
RAM AIR III
Great looking rotor, who plated them for you? I live in western PA and can't find a shop that is doing this type of work.
Old May 21, 2012 | 02:22 PM
b4i4getit's Avatar
b4i4getit
You can't paint the surface of the rotor. As soon as the pads clamp on the rotor the paint is removed. If you want to remove the surface rust after the car has been sitting and the rotor gets wet just go and drive it.
