Lug nut socket
Old Jan 31, 2012 | 09:25 AM
petermj's Avatar
petermj
Default Lug nut socket
What do you guys use? I actually use one with a plastic insert from my Porsche days but the insert is cracked...
Old Jan 31, 2012 | 09:32 AM
BocaC6's Avatar
BocaC6
I've been using a set from Astro Pneumatic (#7835), run around $40 for the set. So far, so good, but don't use them a ton. Includes 17mm, 19mm, 21mm, 13/16in. and 7/8in
Old Jan 31, 2012 | 09:43 AM
Vette5.5's Avatar
Vette5.5
I swap to track wheels several times a year, and actually just use quality 12 point sockets with no problems. I walk around the car with a 3/4" drive ratchet to break things loose, then spin the lugs off/on with a cordless drill when jacked up. Back on the ground, torque wrench everything, and only takes a few minutes. Think the key is, I'm not using any harsh impacts.
Old Jan 31, 2012 | 09:50 AM
azc62006's Avatar
azc62006
Default lugs
4 way lug wrench... and they sell folding ones also.... i wont use a ratchet on mine... it could slip and scratch my wheel. plus the four way provides enough torque to properly tighten the lug nuts down
Old Jan 31, 2012 | 09:51 AM
v1 rot8's Avatar
v1 rot8
I like the Astro Pneumatic set. Have to get me a set of those
Old Jan 31, 2012 | 10:19 AM
Vette5.5's Avatar
Vette5.5
Agree the folding 4 ways are nice, as carry one in my daily car, and a very handi tool. Haven't had any problems with the mentioned large ratchet, cordless drill, torque wrench method though, as done this more times than I care to remember.
Old Jan 31, 2012 | 10:39 AM
JoesC5's Avatar
JoesC5
I use a standard 19mm solid steel socket, as I don't use an impact wrench. A smooth 100 lbs ft tightened by hand is not going to damage the lug nuts.
Old Jan 31, 2012 | 10:56 AM
Jimmy W1's Avatar
Jimmy W1
Soft Socket, 19mm with a 1/2" drive. $32.99 in your in your Mid America Winter Master 2012 catalog........Page 221.
Old Jan 31, 2012 | 10:57 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I've got air wrenches but rarely use them. I just use a normal Craftsman 19mm solid steel socket with an 18" (flex handle) bar. I generally spin my open-ended lug nuts off/on with a socket attached to a hand drill. I finish up with a torque wrench.
Old Jan 31, 2012 | 12:17 PM
petermj's Avatar
petermj
This is what I use right now
This is a 25 dollar socket and the insert cracked, just like my other one. The bad thing is the socket is large and barely fits so it is easy to damage the opening in the wheel.
I was looking at this but this one is a bit pricey...
Are there any other sockets like this one (plastic sleeve on the outside)?
Old Jan 31, 2012 | 09:14 PM
cmonkey713's Avatar
cmonkey713
If you want to go good but cheap get an19mm six point impact socket and wrap the outsise several times with black electrical tape for a cushion. Works perfect and saves $$ for good mods.
Old Jan 31, 2012 | 09:36 PM
Vette5.5's Avatar
Vette5.5
Hmm, kinda sounds like a familiar formula, that works very well. Only difference with me, is using the stock SS clad lug nuts. Still look nearly new though, so not bothering to mess with it.
Old Jan 31, 2012 | 09:39 PM
rcallen484's Avatar
rcallen484
Same here.
Old Jan 31, 2012 | 10:00 PM
mksz51's Avatar
mksz51
6 point socket is a better choice and will cause less "wear" to your lug nuts.
To Lug nut socket
