Nav system
Old Jan 31, 2012 | 10:04 AM
DonF's Avatar
DonF
Default Nav system
I bought a 2011 GS & I am trying to figure out the Nav system. Is it true that in order to program directions that it has to have certain zones in the system? Also that you have to buy from GM diff zones?
Old Jan 31, 2012 | 11:45 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Your car should have come with a complete manual on the NAV. Its fairly easy to use once you learn it. There are two NAV disks for the system, one west and one east. In order to input a destination, you'll see a zone map display which you select which zone its in first, then proceed to the street, address and so on. No, there are no extra zones needed to be purchased. The need for two disks is mostly for the POI's in the system as there are so many, they all can't reside on one disk. The dividing line is the Miss. river for the disks.
Old Jan 31, 2012 | 12:01 PM
DonF's Avatar
DonF
Thank you I will work on it when I get some quiet time, these might both be loaded since I bought the car used with 5000 miles on it.
Old Jan 31, 2012 | 01:11 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Here's a link to a pdf version of the NAV manual
http://www.pdfking.com/2011-chevrole...system-manual/
Old Jan 31, 2012 | 01:12 PM
dgrant3830's Avatar
dgrant3830
The disks only run one at a time within the NAV. It runs inside of the DVD drive under the NAV screen. Eject it and you'll see which is in there and you should have another there in the car or with it for the other coast. A lot of people complain about the NAV being poor and so on, but personally speaking, I find it easy to use with a lot of nice capabilities. Certainly a whole lot better than a BMW NAV...what a joke there. I suppose that once you learn any NAV, then its easy from then on.
Old Jan 31, 2012 | 01:14 PM
JoesC5's Avatar
JoesC5
I think that the later models might just use one disc, but not 100% sure. My 09 factory NAV uses two discs. I also think that there is not a distinct dividing line for the East-West discs, but instead, there is a overlap in the central US. But again, I'm not 100% sure.
I do know the limitations of my Garmin though, as that's what I use instead of the factory NAV. No discs to mess with as I get free lifetime updates, 4 times a year off my computer.
EDIT: I just checked the 2011(year that the OP owns) http://www.chevrolet.com/assets/pdf/...nav_owners.pdf and on page 73 it shows the overlap between the east and west discs. I see I was mistaken about the newer cars having only one disc.
Old Jan 31, 2012 | 01:18 PM
JoesC5's Avatar
JoesC5
This is a direct link to Chevrolet
Old Jan 31, 2012 | 01:30 PM
dgrant3830's Avatar
dgrant3830
As far as I know, its still two disks since 2007 or 2008. My first disk that came with my '07, manufactured Oct. '06, was a single disk. The next revision was two disks and I believe its been two disks ever since. The OP needs to know that only one can be loaded at a time and he hopefully received both. I will also add that since I live in the "West" disk area, yet travel to the "East" disk area several times, usually I have no issues with finding an address in the east area with a west disk. As I mentioned before, mostly its the POI information that's different or available.
Old Jan 31, 2012 | 01:45 PM
mpuzach's Avatar
mpuzach
A quick word of clarification: The map discs don't get "loaded" to the system per se; there is no hard drive. Instead, the disc for the part of the country that includes your destination remains in the DVD slot (the lower one) behind the screen. When using navigation, the system is constantly reading the map data from the DVD. In most cases, you'll just insert the DVD for the region in which you live and leave it in.
Old Jan 31, 2012 | 02:45 PM
DonF's Avatar
DonF
Very good, I get it now!
Old Jan 31, 2012 | 09:32 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
A member here, talon90, has created an excellent tutorial for the nav system; much easier to understand than the regular manual. You can do a search under his name and "tutorial".
Old Jan 31, 2012 | 09:41 PM
RJRSW's Avatar
RJRSW
The new 2012 Version 8 update maps are now back to one dual layer DVD.
It will work in any C6 from 2005-2012 with the nav unit. They appear to have found a new method to store the data because there doesn't appear to be any less POI's available then my two disc 2011 version 7 DVD set and the 2012 disc is also much more up to date.
I have the new 2012 version 8 disc in my 2007 and it covers both the East and West on the one disc and works great without any problems.
Old Jan 31, 2012 | 09:53 PM
RJRSW's Avatar
RJRSW
Originally Posted by mpuzach
A quick word of clarification: The map discs don't get "loaded" to the system per se; there is no hard drive. Instead, the disc for the part of the country that includes your destination remains in the DVD slot (the upper one) behind the screen. When using navigation, the system is constantly reading the map data from the DVD. In most cases, you'll just insert the DVD for the region in which you live and leave it in.
The upper one on my car is the CD slot and the DVD map slot is the lower one.
Old Jan 31, 2012 | 10:05 PM
dgrant3830's Avatar
dgrant3830
Cool about them now using the DL DVD's. I now have to wonder if my '07 DVD drive will read the DL disks or not? I'm guessing it will but will check the nav disc web site and find out.
Old Jan 31, 2012 | 10:16 PM
RJRSW's Avatar
RJRSW
The old 2 disc sets were also dual layer discs so no problem and I'm now actually using the new single disc 2012 version 8 maps in my 2007.
I just checked the old version 2 disc that came with my 2007 car when new and that also was just one dual layer disc back then.
Old Feb 1, 2012 | 03:09 AM
mpuzach's Avatar
mpuzach
Yup, you are correct; my apologies for the error. Original post corrected.
Old Feb 1, 2012 | 10:28 AM
dgrant3830's Avatar
dgrant3830
Excellent! I saw there is a 2012 release now available too on the website for them www.gmnavdisc.com
To Nav system
Old Feb 1, 2012 | 10:33 AM
RJRSW's Avatar
RJRSW
Yes I ordered the new 2012 version from them back in October of last year and have been using it for over 3 months and it works great. Glad to see we are back to just one disc for the total map coverage.
Old Feb 2, 2012 | 11:10 AM
Gearhead Jim
St. Jude Donor '13
We have the new single-disc 2012 version in our 2009. Haven't used it a lot yet, but it does seem to do significantly better when entering a destination business by phone number. On the old discs, it only worked about 50% of the time, other 50% it would gray out the digits before finishing the number. Now, it seems to be good about 80% of the time.
Old Feb 2, 2012 | 12:03 PM
JoesC5's Avatar
JoesC5
Thanks. That's what I must have read/heard about for the one disc application. Glad my mind hasn't completely gone bonkers.
