Wont run
Old Feb 4, 2012 | 04:41 PM
Philco's Avatar
Philco
Default Wont run
I ran my c6 til the low fuel lite came on. One mile later it died. Barely got it restarted and limped to a gas station and refueld with high octane. Only took 15.5 gal so it wasn''t empty. Has not run good since. Wont idle until you run it at 1500 rpm and slowly let it down, starts only with a little press of the gas peddle, still idles bad. I've disconnected the battery to reset the computer. Could the last 3 gals have been contaminated or worse?
Old Feb 4, 2012 | 04:51 PM
Rocketmanwpb's Avatar
Rocketmanwpb
All the gas would have been contaminated if any of it was contaminated. Wonder if you have a fuel pump problem. The fuel pump resides in the gas tank. Have the fuel line pressure checked.
Old Feb 4, 2012 | 04:55 PM
Philco's Avatar
Philco
Wouldn't it run worse at high rpm if the fuel pump was going out? With the split tank scenario it makes me wonder....
Old Feb 4, 2012 | 05:11 PM
Mrc100's Avatar
Mrc100
Fuel pump burned out. Low fuel increased temp of pump resulting in fuel delivery problems. Just my guess.
Old Feb 4, 2012 | 05:28 PM
Gary '09 C6's Avatar
Gary '09 C6
sounds about right to me...
get this properly repaired fast, as you don't want an electrical fire from the bad fuel pump... (happened to me in another car)
Old Feb 4, 2012 | 09:27 PM
Philco's Avatar
Philco
Yep. Gonna check the computer code Sun. The way the fuel transfers from pass tank leaves room for water to stay on the right unless it does run low. Shame on me. Still not ruling out pump.
Old Feb 4, 2012 | 09:50 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
My money is on the fuel pump. Same thing on the wife's car after she kept running on fumes. Cost an arm and a leg to get it fixed.
Old Feb 4, 2012 | 09:58 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Have the fuel gauge checked also.
Old Feb 4, 2012 | 10:02 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
ohhh nooooo ............. Then he'll 'case his fuel mileage sucks .........................
Old Feb 5, 2012 | 01:31 PM
Philco's Avatar
Philco
Codes showed multiple cyl. misfires. Added a can of HEET last night, ran better today but still misfiring, not as bad. After extnsive research on how these tanks work I found threre are two tanks, 9 gal drivers side and 9 gal pass side. Drivers side is the main. It draws gas from tank two and keeps them fairly equal. My theory is the low fuel light came on (3 gal left, 1.5 in each tank)and the drivers (main) tank drew what gas was left in pass side tank. The pass side has water in bottom it was drawn to the main tank hence causing water to get to the engine.. Fill up only took 15.5 gal so there was 2.5 in the tanks when problem started.
Old Feb 5, 2012 | 01:46 PM
VET4LES's Avatar
VET4LES
My guess is the fuel pump got hot and was damaged.
Old Feb 5, 2012 | 01:52 PM
Landru's Avatar
Landru
Originally Posted by Philco
The pass side has water in bottom it was drawn to the main tank hence causing water to get to the engine...Fill up only took 15.5 gal so there was 2.5 in the tanks when problem started.
Plausable, especially if you're using ethanol treated gas.
Continued HEET treatments can evporate that water, get you up & running without a major repair -- with a little luck.
Old Feb 5, 2012 | 02:39 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Sound like the o/p needs to find a way to pick the car up and shake it reeel good until all the water comes out of the tanks ...............
Old Feb 5, 2012 | 02:55 PM
ip-do-tan's Avatar
ip-do-tan
What if you just drilled a hole in it
Old Feb 5, 2012 | 02:58 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
You laugh but ................... iirc, we had a member install quick tap drains.
Old Feb 5, 2012 | 11:37 PM
HOXXOH's Avatar
HOXXOH
I get the low fuel warning real often. Maybe mine survives because I never give water a chance to build up. The gas doesn't stay in the tank very long either when driven often.
Old Feb 6, 2012 | 12:15 AM
Marc V.'s Avatar
Marc V.
Fuel injectors can be damaged from running out of fuel. They are lubricated internally by the fuel. Unlikely, but possible.
To Wont run
Old Feb 6, 2012 | 03:39 AM
EDinPA's Avatar
EDinPA
It shut off while it still had gas. So you didn't run out, causing it to stop. Something else went wrong.
As noted, you likely overheated your pump and messed it up. A weak pump may be causing low fuel pressure. This could be your hard start and idle. The car is expecting more fuel then the pump is delivering and running lean.
Lean is bad. Lean will do bad things to your engine.
Old Feb 6, 2012 | 04:52 AM
druidcat1115's Avatar
druidcat1115
Sound a lot like your fuel pump picked up a slug of water. Use a good gas treatment for the water and hope its not a lot. If you have a couple of gallons of water, you may have to drop the tanks and clean them.
Old Feb 6, 2012 | 07:50 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
You need to do some more research. http://www.hessh.de/Corvette/FuelTankSystem.pdf The venturi in the right tank is sucking right off the bottom of the tank. The right tank is always empty when the gas gauge reads below half. There is no difference at all in the right tank after you use the first 9 gallons.
The left tank is also sucking right off the bottom although in a well. It is very doubtful that any contamination in the tanks suddenly decided to move when you got to the DIC warning. The DIC warning is set at a safe level. 15.5 gallons is not out of line. Lots of people regularly go to the warning. You still had 2.5 gallons over the pump when you stopped. That should be plenty to keep the pump cool unless the pump was already weak.
If you get water in either tank that is the first thing that the pump sends to the engine. But, thinking outside the box, what if you had something floating in the left tank. It would never get to the pump until you get low on fuel. Because of the way the overflow fills the right tank, large floating debris would eventually all end up in the right tank but small or recently introduces stuff might be able to get back to the fuel pump in the left.
The proof that it was the pump or the fuel would be in measuring fuel pressure/flow and looking at the fuel being pumped.
