Fob
Only one FOB came with the car when i bought it last year (2008 LS3, coupe). To start the new season, i'll buy another one. I did a couple of search, but nothing that answers my specific question.
How can i know if the one i have is the #1 or the #2 FOB ? In order to buy the right one, i want to make sure the one i have is the other.
Marc
>>C6 Fob Programming and Glove Box Slot Testing Procedures<<
The first put in during the process becomes #1, the next is #2. The car is probably coded to 2 FOBs already and you need to start with a clean slate to have the "memory" function of the FOBs
Elmer
Every C6 comes from the factory with 2 FOB's, #1 and #2. ONLY the #1 and #2, the first 2 FOB's programmed to the car, can access the memory functions associated with your 3LT. The car's system will accept up to 4 FOB's total at any one time.
If you buy a new FOB and just add it to the car, it will be either #3 or #4 depending on how many are already programmed. Consider this, someone out there has one of the original FOB's that came with the car, because you only received one. That means there is the possibility, though remote, that your car is vulnerable to theft via that missing FOB.
So, when you buy the new FOB, you need to program the new one AND reprogram your existing one and I assume you want both to have access to the memory settings. You will need to either have a dealer program both for you, for some FEE, or do it yourself using the LONG programming procedure that erases ALL existing FOB's and starts over fresh. In that case, what becomes FOB #1 is the first one you program regardless of the number stamped on it, what becomes FOB #2 is the second one you program regardless of the number stamped on it.
Here are the programming procedures proven to work:
http://forums.corvetteforum.com/c6-c...tructions.html
Then reprogram both fobs using the long procedure that deprograms all other fobs that you don't have. It will also allow you to program the #1 fob that you have as no. 1 and the #2 fob as no. 2. That way the engraved number will agree with the programmed number.
From GMPartshouse (forum dealer)
http://forums.corvetteforum.com/newr...y&p=1579968162
2008 Key & Key Fob Upgrade
2008 Key Fob Photograph
http://www.gmpartshouse.com/accpics/08fob1.jpg
08fob1 - #1 Key FOB – $104.40
08fob2 - #2 Key FOB – $104.40
There seems to be confusion as far as what the FOB comes with. As you can see in the picture below you have the black part of the FOB and then the silver part. The silver part of the FOB is actually the key and it DOES NOT come with the FOB!
25995382 – 2008 Key (Does not come with FOB) – $44.82
The long procedure only takes about a half hour total. It is well worth the time and effort. I did find that I had to take all of my FOBs outside, so the car couldn't "see" any of them when I started the procedure.
Only $7/ea at:
http://www.thejacketstore.com/servle...e-Smart/Detail
Yes, make sure you get an integral key. And after you get it cut, make sure it works.
You can also get extra keys made for under $10. Use key blank B-106 (same as a Saturn). I keep one in my wallet.
This is not good!
