Anyone have issues with 305/30/19 tires on stock 10" wide rims?
#42
Just came across this thread and I'm curious to know if the 255/40/18 fronts and 295/35/19 rears would be a good match... This doesn't seem to be a popular combination but I'm wondering if it's because of the high price and limited selection of the 295/35/19 tires.
#43
Banned Scam/Spammer
Can someone post shots from the rear with the 305/30/19 tires? I just purchased Michelin Pilot Sport PS2 305/30/19 and will get them Monday. I want to see what they look like from behind.
Also, anyone put 265/35/18 on the front instead of the 245/35/18? Will they fit or do they scrub on the front air brake ducts? I am considering the 265/35/18 for the front so just want to check.
The 265/35/19 are only +.51 larger diameter so 1/2 inch and +.79 wider, little over 3/4 inch, so it should not be a problem but you never know.
Any one chime in on the front size?
#44
you are fine. I am running this size on 10" rims.
I would suggest you at least entertain getting the Hankook Ventus V12. It is a great tire and will save you some 800 bucks or so over the Michelin. Look at a few reviews and see for yourself.
Tire Rack is a good option - and if you want to, you can take tire rack's price and get a price match at your local discount tire.
Good luck!
Good luck!
#45
