Is alignment needed?
Old Feb 17, 2012 | 07:22 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Default Is alignment needed?
I am going to put new tires all around my 08 Vert. I purchased it new 4 yrs ago next week. I have 26,000 miles on the OEM GY's. The rear tires have more thread than the fronts but I will replace them anyway. All 4 tires have worn perfectly even. The wear bars are just starting to "Thump Thump" on the front tires. I live in a rural area so I will order my tires online and then take the wheels off myself and bring them to a tire store in Va Beach, Va...a 2 hr drive one way, that knows how to handle chrome wheels to have them mounted & balanced. My question is....Do I have to have it re-aligned if I replace the tires with the exact same size but a different brand?
Old Feb 17, 2012 | 07:43 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
considering your stated wear patterns, no. but considering that this is a new set, I don't think it can hurt to have it done (esp. once every four years), just make sure they really tighten things down when they do it. my take is you've been very lucky not to need one sooner.
Old Feb 17, 2012 | 07:47 AM
teenVette's Avatar
teenVette
Veteran: National Guard
4 years on one set of tires is very good. I would't think you would "NEED" an alignment, but it wouldn't hurt after everything is mounted back on your vette
Old Feb 17, 2012 | 08:29 AM
Flame Red's Avatar
Flame Red
These tires are expensive. I would align it.
Old Feb 17, 2012 | 09:43 AM
ufso's Avatar
ufso
I take off my tires once a year when I do my oil change. Within one year of my last tire takeoff, my front insides were almost to the wires. Somehow they got out of alignment in one year.
Do the alignment, just find a place that will let you drive it on and one that will take your car, being the front is so low. You'll screw the valance going up and coming back down. See if they have 2x4s or something. Just some thoughts.
Old Feb 17, 2012 | 09:50 AM
z51vett's Avatar
z51vett
usfo your front end is aligned from the factory with a lot of neg camber you need 0 camber and toe on the front for good tire wear. The rears need 1/2 degree neg camber 0 toe. Hope this helps
z51vett
Old Feb 17, 2012 | 09:55 AM
ufso's Avatar
ufso
Thanks z51vette for the info. When I had it done last year, I took the specs that were printed here years ago and are up in the top of the page.
Old Feb 17, 2012 | 09:59 AM
Kenny94945's Avatar
Kenny94945
Since perfect wear.....forego an alignment IMHO.
FWIW:
Yet another option would be to have the alignment specs printed out after you install the new tires for future reference.
Again w/ perfect wear....what would you change in your specs?
You could look to corner weighting and ride height then align to a spec recommend by co-members of this forum.
It can be time consuming to get "perfect" specs and then you or a passenger sit in the car, adding your weight, which changes the specs. Again, since you have proper tire wear...I'd skip an alignment.
Old Feb 17, 2012 | 10:00 AM
boraxman's Avatar
boraxman
I would
Old Feb 17, 2012 | 12:03 PM
Landru's Avatar
Landru
With what tires cost? Made it an alignment SOP every new set. For what, an extra c-note? Just makes sense.
Old Feb 17, 2012 | 01:37 PM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
A 4 wheel alignment with new tires is cheap insurance. Do it.
Old Feb 17, 2012 | 01:40 PM
OnPoint's Avatar
OnPoint
The Consigliere
If your wear pattern is fine, I wouldn't mess with the alignment. In the face of a perfectly acceptable wear pattern, wouldn't want to give a shop the opportunity to mess it up.
Old Feb 17, 2012 | 01:43 PM
GOLD72's Avatar
GOLD72
Under the circumstances described, I would have the tendency to leave it alone but monitor the new tires in case an alignment is needed later. I like the old saying "Don't fix what ain't broken!" You never know when you could be worse off for any reason fixing something that hadn't shown that it needed fixin. JMHO.
Old Feb 17, 2012 | 01:44 PM
johnodrake's Avatar
johnodrake
Moderator
Normally I do, but in your case, I probably would not. If you have the ability to get under your car, use a sharpie to mark the alignment and check every now and again to be sure the alignment has not shifted.
GOLD72's Avatar
GOLD72
That's it!!
Old Feb 17, 2012 | 01:55 PM
ohmy's Avatar
ohmy
don't let em touch it!
Old Feb 17, 2012 | 01:56 PM
obxchartercaptain
Thanks for all the input....I am of the firm belief "if it ain't broken..don't fix it" and why give someone the chance of messing it up. I will put the new tires on and monitor the wear. If there was a decent dealership/shop where I could have it checked I would have it done. Like one of the previous posts...cheap insurance...but then I would risk damage by someone who doesn't know what they are doing.
To Is alignment needed?
Old Feb 17, 2012 | 02:02 PM
JoesC5's Avatar
JoesC5
26,000 miles on the original Goodyears. If you have a base C6, that mileage sounds normal. If you have a Z06, please get the alignment checked and send me the results so I can get my Z06 aligned to your specs.
Seriously, it sounds like your alignment is okay, so don't be messin' with it.
Old Feb 17, 2012 | 02:27 PM
speedlink's Avatar
speedlink
New tires, new alignment.
Tires are too expensive not to have the alignment checked!
You may be surprised as to how far off the alignment was.
Old Feb 17, 2012 | 03:36 PM
JoesC5's Avatar
JoesC5
I disagree. If he has even wear that is an indication that his alignment is Okay. What does he have to gain by having someone alter, what appears is a good alignment? Now if the car is pulling to one side, he needs to get it checked, but if the car drives right and shows no abnormal tire wear, an alignment is not needed.
I have only had five alignments done to my cars over the past 50 years. Two were because I changed out the front springs in the cars(hot rods), one was because the car was scrubbing to much in tight turns in one direction, one was because I slid on some ice and smacked the curb, and then once on my Z06 last year when it was obvious that I needed an alignment because my right front tire was wearing badly on the inside. But on my Z06 I did hit a bridge deck at 65 MPH where they had scraped the asphalt off the road(about 2-2.5 inches) and didn't put any temporary ramps in to the concrete bridge floor, thanks to the Kentucky Highway dept.
