What causes . .
I did have the Chevy dealer do a 4-wheel alignment in June, right after I got the car. Here's what I had them set:
Front camber = -0.8, caster = 8.0, toe = 0
Rear camber = -0.5, toe = 0
Been running the standard 30# in all 4 tires, except about 2 extra # in the winter in case of 20° to 30° temps.
(No Z51 option on car).
Is the tread wear even across the tire or are you seeing uneven wear or edge wear? Generally, rapid, even wear across the fronts is from taking turns at higher speeds and scrubbing some material off the face of the tread.
The '05 service manual lists the alignment specs as follows:
Suspension
Front
Camber
-0.45° ± 0.60°
Camber Cross Tolerance
± 0.60°
Caster
7.90° ± 0.60°
Caster Cross Tolerance
± 0.60°
Total Toe
+0.10° ± 0.20°
Steering Wheel Angle
0° ± 3.50°
Thrust Angle
Several 40 mph streets in Tullahoma, but most are 30 mph. I don't drive or turn that fast in town. Interstate route that I drive has 5 or 6 long sweeping turns of about 30° to 60° in 50 miles.
However, I do have a pretty sharp turn in my back yard, going into my carport. Have to make a 90° turn in about 30', then similar turn when backing out and turning to go forward out the driveway. But I had that with the 06 coupe.
The alignment I had the dealer set was what Pfadt recommended for 100% street use.
The ramps don't have must of a turn to them, though, so I doubt if I ever see more than 0.25 to 0.3 G.
Also, even at low speeds, the front wheels will have more scrubbing while turning because of their width(as opposed to the narrow tires found on your DD). I try and make more sweeping corners then tight turns when possible, to lessen the scrubbing.
I've been driving like that for 5 decades and it's second nature.
I could be funny and say the tire wear is your car's way of saying you are having too much fun. But you probably wouldn't laugh.
More seriously-
If the tread wear is even, that usually means alignment and inflation are correct. And we know you took those issues out of the picture. The roads you drive on probably have the same surface as before, or pretty close.
It does seem that some people experience abnormal tire wear for reasons we never can discover. I have begun to suspect that there is some tire-to-tire, or at least year-to-year, variation in the life of the tires.
I'd chalk it up to the X-factor. Decide what kind of replacement tire you want, then just get 'em and get back to enjoying the car.
Also, as I indicated above, I do have to make a slow sharp turn to get under my carport, which I do about 10-12 times a week.
More seriously-
Maybe a combination of those things, slow tight turns (although I had them before), slightly harder braking, and rougher pavement is causing it.
Thanks for the responses.
It's my DD, it's my 6th Vette, and I'm a Vette nut, so I'll buy more tires and put up with it.
Sounds like you got a good set of GYs. I think there's a direct correlation between brake pad and tire wear ...
If I lived where you do in TN I'd prolly get about 0 miles of wear. Damn, that's just not fair. Living as close to Deals Gap as you do ...........................
I could be wrong but I suspect the tire compound can sometimes vary (perhaps due to poor quality control at the factory). At one track I run on there’s one particular off-camber curve (with an abrasive surface) that’s hard on tires. One weekend I destroyed a virtually new set of front track tires….the rubber peeled-away damn near cording the tires. Other weekends, using the same make tires there’s no problem.
Good luck.
