Is it safe?
Old Mar 1, 2012 | 11:33 AM
Apocolips's Avatar
Apocolips
Default Is it safe?
I’ve always been told that when charging a battery to do it in a ventilated area. I have a Battery Tender Jr. and have it charging with a car cover over the car. Should I only use the Tender with the cover off?
Old Mar 1, 2012 | 11:38 AM
dvilin's Avatar
dvilin
I have stored my Vette each Winter with the battery tender hooked up and the car covered. I have had no problems and would not be concerned.
Old Mar 1, 2012 | 12:20 PM
Don-Vette's Avatar
Don-Vette
Same here
Old Mar 1, 2012 | 12:23 PM
EDinPA's Avatar
EDinPA
Let it air out before connecting / disconnecting the wires as they may spark. The charging process produces explosive hydrogen gas.
Old Mar 1, 2012 | 01:32 PM
Apocolips's Avatar
Apocolips
Wow, so smoking is out of the question?
Old Mar 1, 2012 | 02:23 PM
mikeCsix's Avatar
mikeCsix
Hydrogen gas is pretty explosive. In my chemistry class, the professor filled some small balloons with hydrogen gas and tied them with string so they were floating around the auditorium when we unknowingly walked into class. As the lecture progressed, he tied a candle to the end of a long stick and proceeded to punctuate the lecture by lighting off one of the balloons, nobody fell asleep during class that day! The gas has to be pretty concentrated to go off like that, but why take the chance?
Smoking is always out of the question.
Old Mar 1, 2012 | 05:06 PM
CO Lightfoot's Avatar
CO Lightfoot
I doubt there's hardly any hydrogen gas produced by a battery maintainer (like my CTEK 3300).
Anyway, even if a small amount is produced, it's lighter than air and will quickly disperse upward thru the car cover.
Old Mar 1, 2012 | 08:31 PM
Le Mans Z06's Avatar
Le Mans Z06
Interesting, mine is covered and with the garage door closed I have smoked out there.
Old Mar 1, 2012 | 08:35 PM
C3 Vette Fan's Avatar
C3 Vette Fan
Old Mar 1, 2012 | 08:49 PM
St.Char's Avatar
St.Char
X3
Old Mar 1, 2012 | 08:57 PM
EDinPA's Avatar
EDinPA
If everything is functioning properly there should not be a problem. But when was the last time you tested your charger. The problem usually occurs with a malfunctioning charging system or trying to jump a car. The hydrogen collects in the battery that also unfortunately is filled with battery acid. If you explode a battery with a spark from connecting or disconnecting it there is a good chance of getting battery acid in your eyes and there is no easy fix for that.
Even though the risk is low, the permanent damage that can be caused makes it worth taking simple precautions.
Old Mar 1, 2012 | 09:30 PM
Marc V.'s Avatar
Marc V.
There should be no risk with a battery tender. It is a slow, low amp charge.
It's a good practice to never connect to your battery when the charger is on to avoid any arcing.
A regular battery charger produces hydrogen gases at a higher charging rate. That should absolutely be done in a ventilated area. I have personally seen several batteries explode in my 22 years at a dealership.
Old Mar 1, 2012 | 09:43 PM
rcallen484's Avatar
rcallen484
Everybody ALWAYS wants a picture. So:
Old Mar 2, 2012 | 04:18 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Your tender provides a slow, low amp charge over a long period. Don't confuse that with a charger.
Old Mar 2, 2012 | 08:07 AM
CyberGrayGS's Avatar
CyberGrayGS
Old Mar 2, 2012 | 08:23 AM
Apocolips's Avatar
Apocolips
Great responses, thanks everyone for the information.
To Is it safe?
