Question for you manual tranny guys!!!!!!!!!!!!!!!!!!!
A fun problem to have, you really didn't want your wife in the car with you anyway did you? Simply sounds like you are letting out the clutch too fast and not accelerating with the gas pedal as you smoothly let out the clutch. If you don't give the car a bit of gas you will have very quick, snap your neck shifts all the time. It takes time to get use to a stick again and your dealing with a car with a lot of torque which will be a lot less forgiving than a 5 Speed Honda Accord.
Don't stomp the clutch pedal.
Actually you don't want to "let off the gas"...What you want to do is rev match and let the clutch out smoothly from gear to gear as you go up......You get the shifter into the next gear quickly and add a little gas to maintain the rev while the clutch is down as you lift up on the clutch going into the next gear (almost one motion)..Your ear is your friend so practice with radio off lol...
My wifes head doesn't move unless I want it too....
With practice you can be as smooth as butter..soon you feet will think for you.
When you get it right it sounds sort of like an automatic only better and just as smooth.
#33
In my recent experience of doing what you're doing I'd guess you are dumping the clutch as quickly as possible while hitting the gas hard. I try to avoid doing this; not so much for passenger comfort but because it is still relatively cold out and the tires break lose a little more than I'd like.
I've noticed by wife's head bouncing around but so far she seems to really be enjoying the whole thing.
#34
Where I was born and raised you had to take your driver license road test on a stick. Unless you wanted a license that only allowed you to drive autos (wich nobody wanted sinde autos where looked at at as handicap equipment). My first time driving an auto transmission was when I came over to the states at age 28. Still se autos as handicap equipment. It's not that I dislike them, they are just so boring to drive.
To the thread starter.....the stick handling is only 10-15% of the reason you are jerking.....the more importent part is how you work your pedals.If you cant get your pedal sync right it doest matter how smoth you are i your stick handling.
#35
After six years with my C4 I knew how to work that 6speed like walking. I have had my Grand Sport now for about six weeks and am still trying to get used to it. Honestly I think it is trying to get used to me too. I am working on dialing in my slow speed shifting for now. My fast shifts are terrible because I haven't gotten the pedal coordination together yet. The clutch on my new car lets out down at the bottom of the pedal where my old car was closer to the top. Big difference in muscle memory. I think when I am good at slow speed the fast ones will be easy to tune in.
Keep practicing.
Matt
Keep practicing.
Matt
#36
Under hard acceleration, assuming you know how to launch and speed shift, the gear changes should be quite similiar to that of an automatic transmission, and have a similiar effect on your passenger. While downshifting, if you rev match correctly, the process should be smoother than with an automatic.
#37
#38
The whiplash is caused by opening the clutch while you're still accelerating then closing it quickly with open throttle. I'd say its normal, if you want to smooth it out you can feather the clutch rather than dropping it, chews up your clutch a bit. Even if you rev match your upshift perfectly you'll still get the 'forward' jerk from opening the clutch under acceleration.
try an experiment - 1st gear WOT then let off the gas and open the clutch simultaneously, you'll feel the weight transfer forward. can't really get rid of that transfer if you wanna go hard.
#39
Picked up my MN6 in August. I have about 1500 miles under my belt. I never owned a manual but have driven many albeit 15 years ago. I find it is harder to be smooth going from 0 to 35 versus when I can get out of the gate quickly, say from like a toll plaza and get her up to 65,70.
OP - good luck, we will get smoother
#40
Hey Gary, you threw me into the back of your seat 50 times.....oh, wait - we agreed we would not tell anyone. My bad :o
we were burnishing the brakes on his ZR1
