flappy thing fix
Old Mar 24, 2012 | 05:58 PM
R&L's C6's Avatar
R&L's C6
Originally Posted by JimmyLee
I didn't like the bar coming down on my roof when I was storing the roof in the trunk. Last week I cut the entire curtain off with scissors and it looks great. (cut about an eighth inch away from the stitch. When it stretches upon install you won't be able to tell that it was a do-it-yourself job). Also, I have the partition, which keeps the area private.
I also have a partition and I just used safety pins to attach the flap back.
Old Mar 24, 2012 | 07:40 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Originally Posted by CaryBob
I used a steel rod from Ace Hardware cut to fit exactly between the wheel wells. When closed, it is heavy enough that the seam lies flat on the floor and doesn't swing around or move at all even with the roof panel removed.
What diameter???
Old Apr 1, 2012 | 02:03 PM
skikev's Avatar
skikev
Just fixed mine with velcro. Used fabric fusion velcro from michaels craft store with a half price coupon total cost $3.00. It is heat activated glue. Attached a two inch piece to each corner using an iron for 90 seconds and no more flapping. Looks good too.
Old Apr 1, 2012 | 02:29 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Originally Posted by Quick Silver Z
What diameter???
1/4-20 ROD. I did this in 07 when I first got my Z06 and it works good!
Old Apr 1, 2012 | 02:31 PM
switchplanner's Avatar
switchplanner
I tried the 1/4" wood dowel and it still flew all over the place with the top off and the windows down. Took it out and may try the velcro method mentioned above.
Old Apr 1, 2012 | 02:38 PM
MIGHTYM0USE's Avatar
MIGHTYM0USE
Cool idea w velcro
Old Apr 1, 2012 | 04:25 PM
6spdC6's Avatar
6spdC6
Wood dowel is too light get the metal 1/4-20 rod.
Old Apr 1, 2012 | 05:57 PM
Bill Dearborn's Avatar
Bill Dearborn
For the two minutes it takes to remove the cover and reinstall it why bother?
Bill
Old Apr 1, 2012 | 08:32 PM
gr1634's Avatar
gr1634
Default Flappy Thing
I put the qtr inch wood in and it works just fine -- thanks for the thought
