Battery?
Your pony car and the Vette are NOT the same animal. Vettes have a lot of electronics. Those electronics use energy. Even when parked.
If/when you get a Vette and it sets longer than 21 days at a time you run the risk of running down the battery. get a good tender and you will NOT experience the issue. It's not issue really, since we know how Vettes are designed to function.
There are some new members which come onto this site to start BS. Not saying that you are, but that is likely reason for the first response. When do you plan to get a Vette?
I have to say that I find it odd that GM design a car that can not sit for more than a week without needing a charge to the battery before starting.
You do NOT have to have that factory tender. That option did not appear until last couple years. Most of us who have these cars and not dd them, buy a good tender. I have on which plugs in my cig adapter. Works great and have NEVER had a issue. This is my second C6...vert/C6Z.
I store my Z for the winter and have always used the tender save for my '08 coupe back in '07-'08 and I never had a problem starting it. Just an inexpensive option to avert problems.
Most makes of cars have some type of issues including the Fords. I had a couple of late model saleens and a shelby gt500. the mustang transmissions were on the weak side (5 speed manuals) and they went out at 2500 miles. The shelby was better and was problem free.
The dodge trucks had some weak transmission issues and so on and so on.
When your car comes in, be sure and post up some pics, find a corvette group near you and go on some fun runs and events. I'm not sure where you live but there are several big corvette events around the country. Next one i believe is at the corvette museum in bowling green, ky on April 26, 27 and 28!
For the ZR1, I use the cigarette plug option & run it under the door, for the CTS-V, I used the eyelets at the battery (in the trunk) & just plug it in when needed.
If I'm not using the car for more than a few days, they get plugged in. I've killed too many batteries over the years from sitting & finally figured that the battery tenders were cheaper than buying a new battery. With 4 cars, a truck & 2 motorcycles....that's a lot of batteries.
As noted, some C6's do suffer from unusual battery drain (sometimes referred to as "DBS"....dead battery syndrome). It's no consolation if you have the problem but I tend to think the problem affects only a minority of cars. IMO unless you're storing the car for the winter (and not driving it at all) I wouldn't worry about it. See what happens. If your driving routine necessitates a battery tender you'll know at some point.
Good luck!
I have just got in the habit of either disconnecting battery, or connecting a charger, if not going to start any vehicle for more than 5 days or so.
If you want, you can buy the "Corvette" charger kit from one of the forum vendors, it is just a CTEC charger with a Covette logo on the carry case. You can get the CTEK 3300cheaper and is the same thing, except maybe better as it comes with a ring terminal and clamp connections. Get the extra $10 cig. lighter adapter too if you want that, and you have an overall better package.
I still think the cord under the door will fatigue the door seal over time. I have been leaving mine come out the hatch, and not closing completely, so no pressure.
I plan to do some type of external connection for convenience. My battery is in trunk, so I may just run a quick connect out the hole by the license plate lights, and use a wire retainer under one of the plate screws to keep it from flapping around. If battery in front, would maybe just zip tie in the grill.
Here are two nice external connection options for the charger. Shop around, most all the forum vendors carry the chargers, and Stealthlink connection kit.
Stealthlink
http://www.southerncarparts.com/corv...it-p-3815.html
Magcode Magnetic
http://tmaxxpowerpipes.tripod.com/id127.html
