Traction Control
Old Apr 8, 2012 | 10:22 PM
jdobbie007's Avatar
jdobbie007
Default Traction Control
what changes is made to the car when it is in competition mode?
Old Apr 8, 2012 | 11:27 PM
ChevyDave's Avatar
ChevyDave
(copied from others posts....)
1 hit...you have control of the rear wheels, and the computer does everything in it's power to keep you off the guard rail.
2 hits...you have control of the rear wheels, and the computer doesn't try as hard to keep you off the guard rail.
Holding it down for the full 5 seconds.....the car is all yours...no help from anyone. A good choice if you happen to own a 'body shop'.
see post #20 (and others if you still want more info)
http://forums.corvetteforum.com/c6-c...ss-or-two.html
Old Apr 8, 2012 | 11:34 PM
jdobbie007's Avatar
jdobbie007
Thanks for the reply, i'll try to keep it out of the body shop!
Old Apr 9, 2012 | 12:00 AM
Nice Ride's Avatar
Nice Ride
Base C6 Corvette is 430HP. That is a lot of power. More than enough to bite you if you play with the Traction Control. Not trying to tell any one what they should do but I had a sweet 98 C5 and that car pre dated Traction and Stability Control. It also had 80 less HP. I have owned Corvette off and on over 40 years and understand these cars pretty well. Even so, the 98 got loose a couple times when I did not expect it. IMO, wise to leave the Traction Control engaged and forget about it.
Old Apr 9, 2012 | 12:05 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Competition mode shuts off traction control and uses a lesser level of active handling intervention (such as you might want when learning to drive on a road course).
Old Apr 9, 2012 | 12:48 AM
jdobbie007's Avatar
jdobbie007
I had the active handling kick on the other day and I didnt care much for it, I like to have control, I also race stock cars so I like to be able to correct a slide myself. The active handling caught me by suprise. Thanks for the heads up!
To Traction Control
