2012 iPod/iPhone Sync Cable Issue Solved
Old Apr 10, 2012 | 11:44 AM
Salty Dawg's Avatar
Salty Dawg
Salty Veteran
St. Jude Donor '11
Default 2012 iPod/iPhone Sync Cable Issue Solved
Ok, I thought I would post this for the benefit of the forum.
After calling several Chevrolet dealerships and searching Best Buy, Radio Shack, Target and Walmart I found the sync cable for the 2012 Vette. It's a USB and an aux cable input in the armrest. I found the cable on Amazon for $5.00.
It was frustrating knowing that Chevy would put this interface in their cars and not make the cable available in their parts department.
Any way, if you need one of these cables just search usb/aux sync cable.
You're welcome!
Cheers,
Mike
Old Apr 10, 2012 | 11:51 AM
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
You're welcome!
Cheers,
Mike
Nothing really unique about that cable. It is the same one that connects the Iphone/Ipod to the charger.
Old Apr 10, 2012 | 11:53 AM
Salty Dawg's Avatar
Salty Dawg
Salty Veteran
St. Jude Donor '11
This cable has the 3.5 mm cable that's needed to play music. The cable that comes with the iPod/iPhone has the USB only.
Old Apr 10, 2012 | 11:59 AM
Cavi's Avatar
Cavi
all the cables that have come with my ipods play music just fine through them.
Old Apr 10, 2012 | 12:02 PM
flashburn's Avatar
flashburn
Is that cable needed for the 2012 w/ Nav? Is there only a USB input in the car, or is there also an AUX audio input? Trying to figure out what I need before I pickup the car. I'd like to stream audio from my iPod as well as occasionally from my Android phone.
edit: Nevermind, after looking at the cable, I don't think it's needed. The Nav unit must also have a AUX input in the center console?
Steve Snake Driver
OK, now I'm confused. There is a USB port inside the armrest. You can plug your I-whatever into that USB port using the same cable that is used to recharge your Ipod/Iphone/Ipad. And you can select and play music from your I-device using the Nav/Radio display. No need at all for a 3.5 mm cable. If non-Nav radio, then I may be wrong, but if you have a 2011 or up w/Nav, then you don't need anything special.
Old Apr 10, 2012 | 12:04 PM
ip-do-tan's Avatar
ip-do-tan
Withdrawn
Old Apr 10, 2012 | 12:07 PM
flashburn's Avatar
flashburn
Is there a AUX audio input for non-i devices?
edit: Nevermind, I found this picture:
I'm not sure why a cable with both iPod interface and aux on it would be needed.
Old Apr 10, 2012 | 01:05 PM
CBRXX's Avatar
CBRXX
I haven't tested any of this yet, I know for sure it is supposed to play audio files directly off of a USB storage device, like a memory stick. I assume even a portable hard drive would work. Also, an Android phone contents can be read via USB like a memory stick.
I was under impression on the 2012's w/NAV it should also read and even control an Ipod via the USB w/o using the headphone style audio jack I don't have an Ipod to test.
That audio jack is for devices like your basic mp3 players, etc. that only have a headphone output.
Old Apr 10, 2012 | 01:06 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I asked a similar question about cars without the Nav ...
If you don't have Nav, you won't have the USB input port in the console, but you will have a small 3.5mm input port on the face of the base Delco radio (at least on my 2011 GS)
To listen to music you have stored on your iPhone (I guess an iPod too), all you need is a wire that has a 3.5mm stereo plug on each end. You can get this at Radio Shack, etc. Then you plug one end of this wire into the headphone jack on your iPhone, and the other end into the little input jack on the face of the radio ... Set the radio to Aux, and the music from your iPhone plays through the car's audio system.
These also come in the non-coiled wire variety
Old Apr 10, 2012 | 01:44 PM
Steve Snake Driver
Originally Posted by CBRXX
I was under impression on the 2012's w/NAV it should also read and even control an Ipod via the USB w/o using the headphone style audio jack...
That is correct. You just hit the IPOD button on the Nav SOURCE screen and you can control it without any problems.
Old Apr 10, 2012 | 03:08 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You're welcome!
Cheers,
Mike
You don't need an auxiliary cable to play music from your iPhone on a nav equipped car. You simply plug in the USB cable that comes with your iPhone/iPod in to the USB port and control the playback with your head unit and the sound comes out the speakers. If you don't have an iPhone, you can plug any device's headphone output in to the 3.5mm jack in the console but you do NOT need both plugged in. The USB will also charge your phone while it is playing.
Additionally, you can plug any USB thumb drive or hard drive with music files on it and it will also play through the stereo.
The reason no dealership carried what you were looking for is because it simply isn't needed.
Old Apr 10, 2012 | 03:10 PM
talon90's Avatar
talon90
NCM Ambassador
Yes, this is my photo. That picture is of the interface for the vehicles equipped with a navigation radio and it is located in the center console.
Pictured is a USB jack for thumb drives, hard drives and iOS devices (iPhone/iPad/iPod) and a 3.5mm aux input jack for all other devices which you would plug in using the headphone or audio out jack on the device.
Old Feb 5, 2016 | 06:10 PM
RUHERS's Avatar
RUHERS
1st Gear
Default IPOD Aux cable
Hello,
I have a 2012 with Nav and I plug the USB into the USB and the nav says its not compatible
You're welcome!
Cheers,
Mike
Old Feb 5, 2016 | 07:18 PM
unixcorn's Avatar
unixcorn
Originally Posted by RUHERS
Hello,
A USB what? An iPhone, Android phone, a USB stick? If you are talking about an iPhone cable, then are you certain it's Apple certified? You should be able to plug the USB cable you charge your phone with into that port and be able to play music. If you are trying to use an Android phone, then we need someone else to pipe in.
Also, this is an old thread. Probably best to start a new one when you have a question rather than resurrect old ones.
To 2012 iPod/iPhone Sync Cable Issue Solved
