Speed Bumps
Old Apr 22, 2012 | 12:19 PM
antt's Avatar
antt
Default Speed Bumps
Should a 2008 C6 clear most speed bumps?
I've had the car for 4½ years, and I've managed to avoid speed bumps for fear of hitting the rocker. I'm starting a new job tomorrow and the speed bumps cannot be avoided, and looks like the front air dam will definitely hit and the rocker clearance will be close.
The front air dam clearance is 3½" and the rocker behind the front wheel is 5¼". Is there a way to increase the clearance by suspension alterations/adjustments?
Old Apr 22, 2012 | 12:26 PM
Deceptikon's Avatar
Deceptikon
The air dam is flexable and will scrape. Mine is 2 inches from the ground and hits everything. I have lowered my whole car on the stock bolts and never hit the rockers on speed bumps. Drive over them very slow.
Old Apr 22, 2012 | 12:27 PM
ChevyDave's Avatar
ChevyDave
My height is 6 13/16" . You can adjust, see #34..
http://forums.corvetteforum.com/c6-f...essions-2.html
Old Apr 22, 2012 | 12:28 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
dude the b and p aren't even close enough for you to say typo
take them at an angle
Old Apr 22, 2012 | 03:10 PM
Wyndridge3's Avatar
Wyndridge3
take them at an angle [/QUOTE]
Old Apr 22, 2012 | 03:13 PM
Mad*Max's Avatar
Mad*Max
traverse the speed bumps at 45 degrees, if possible
Old Apr 22, 2012 | 03:34 PM
Orange05_C6's Avatar
Orange05_C6
If you hit them doin exactly 37.3mph, it will be as if they arn't even there.
Old Apr 22, 2012 | 03:50 PM
Kadorja's Avatar
Kadorja
Eh my lucky speed is about 20mph
To Speed Bumps
