Changing brake pads question???
Old Apr 23, 2012 | 11:29 PM
C6Vette710's Avatar
C6Vette710
Default Changing brake pads question???
I am about to change all brake pads on my 2006 C6 Z51. I was wondering if it was that necessary to resurface the rotors? The dealer told me I did not have to but recommends it for longer life and no brake squeal. That if not resurfaced they would for sure squeal. Also there is a big price difference from just installing pads to resurfacing rotors. I would rather just do the pads if I am able to. What do you guys think? Thanks
Old Apr 23, 2012 | 11:41 PM
Marc V.'s Avatar
Marc V.
If you have Z51 drilled rotors, they can't be resurfaced.
I would recommend replacing the rotors for the best performance. They are not that expensive.
Old Apr 23, 2012 | 11:53 PM
jpee's Avatar
jpee
I had 6000 miles on my OEM break pads (Z51) and changed to Ceramic pads, never touched the rotors, and I now have 30,000 miles on the car (about 24,000 on the Ceramic pads) never had a squeal or any dust...
BTW I also drag race it most weekends, but am easy on the breaks as I have over 1/2 mile to slow down after crossing the 1/4 mile finish line..
Old Apr 23, 2012 | 11:57 PM
kctay's Avatar
kctay
They can be resurfaced if within machine to specs, but you will have plenty of people like Marc here chiming in with opinions that have little to do with facts. Good luck.
Old Apr 24, 2012 | 12:00 AM
C6Vette710's Avatar
C6Vette710
Yes, someone told me that I cant because they are drilled. And yet the dealer tells me I need to. So you are saying my only options are change the pads and rotors or just the pads?
Old Apr 24, 2012 | 12:01 AM
C6Vette710's Avatar
C6Vette710
Thanks for the info
Old Apr 24, 2012 | 12:03 AM
RowboatLS3's Avatar
RowboatLS3
you can resurface those rotors. if you have a vibration when braking at higher speeds id recommend resurfacing the rotors due to them being out of round causing the vibration. every brake job i do i cut the rotors. but if you like for your rotors to last longer you dont HAVE to but i would recommend it.
Old Apr 24, 2012 | 12:14 AM
C6Vette710's Avatar
C6Vette710
Thanks. The pads need changing, but the rotors feel fine all around. I have only changed all pads once at 15k miles now I am at 35k. I just don't want to run into any issues down the road like noises or vibration. But I also don't want to spend extra money when not needed.
Old Apr 24, 2012 | 12:29 AM
kctay's Avatar
kctay
Look, this is the last time I'm going to chime in.....they can be machined...I do it for a living.
Old Apr 24, 2012 | 02:51 AM
AtHomeSoda's Avatar
AtHomeSoda
Default 0k...
I have a 2006 Z51... I had mine turned, $15 ea, No they are NOT cheap to replace, like Stock Base Rotors... The whole job is WAY easy to do, total cost to do front & rear with Ceramic Pads was about $300 + 2 hours of my time...
Old Apr 24, 2012 | 06:06 AM
Don-Vette's Avatar
Don-Vette
I don't change the rotors every brake job on my truck,but on my GS I will put new rotors and pads on,less than $400 from forum vendor Brakemotive.
Old Apr 24, 2012 | 10:32 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Why are you chaging brake pads so often? If your just street driving I would look at a longer lasting pad like the Carbotech 1521.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Apr 24, 2012 | 03:43 PM
C6Vette710's Avatar
C6Vette710
[QUOTE=carbotech adam;1580638808]Why are you chaging brake pads so often? If your just street driving I would look at a longer lasting pad like the Carbotech 1521.
Thanks I will check into them. But I have been to the track with these pads twice.
Old Apr 25, 2012 | 09:17 AM
Carbotech Adam
Supporting Vendor
[QUOTE=C6Vette710;1580640788]
Gotcha thats a whole diffrent story.
Old Apr 25, 2012 | 09:53 AM
TJay74's Avatar
TJay74
As said, drilled and slotted rotors can be turned just as easily as a regular blank rotor. I have turned sets of them in the past with no issues.
Old Apr 25, 2012 | 10:42 AM
EyeMaster's Avatar
EyeMaster
While it's easy to find rotors for the Base Vette for less than 100$ each, it's very hard to have z51 rotors for less than 150$ each. I just ordered the cheapest blank rotors for my Z51 that I could find (no cross-drilled or slotted, just blanks) made by Centric with high carbon content and they are 125$ front and 110$ rear. The next step up was 140$ for slotted only. Then there's the DBA 4000 or something like that, at 200$ per corner.
So you see, z51 rotors are easily 2x more expensive than base rotors. I can understand the wish to get them machined instead of just buying new ones.
Old Apr 25, 2012 | 12:31 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I don't know what kind of mileage is on your car or how it's typically driven. In the absence of any noticeable brake issues I'd simply change the pads (easy to do). Remember to bed the pads in properly.
http://www.zeckhausen.com/bedding_in_brakes.htm
There's no way for me to know the condition of your rotors but I wouldn't be surprised if the dealer was recommending work that wasn't truly needed.
To Changing brake pads question???
