Theft deterrent issue?
Thanks,
(also posted in the Tech section)
I'd try battery disconnect, wait short time, reconnect. Does your doors& windows&other stuff work fine?
Have you tried to see if codes stored in history using a Tech 2?
research note: the only thing i found was a person having this light, also had a electric inside door lock not working, fixing that fixed the light. so based on that i would say that deterent found something not connected/loss of signal, door/hatch/other verify everything working.
I will make note of this in my owners manual should I ever see the issue pop up again.
